Volks AutosSky Insurance
    May 2009
    11
    Engine codes advisory on MOT 2.7T Petrol
    Hey all,
    We have a 2.7T V6 Petrol A6 Avant which has been throwing up some codes that I would really appreciate some help with.
    Here are the codes as taken from the printout from the garage...
    P1459 Exhaust gas temperature sensor 2 signal improbable.
    P1136 Additive mixture adaptation for air (Bank 1 sensor 2) System too lean.
    P1138 Additive mixture adaptation for air (Bank 2 ) System too lean.
    P0300 Combustion failure detected faulty (which I think should actually read 'Random/Multiple Cylinder Misfire detected)
    P0306 Combustion failure detected cylinder 6 faulty
    P0302 Combustion failure detected cylinder 2 faulty
    I have tried to look up the first 3 codes here...
    OBD II Fault Codes
    The 3 top codes don't seem to correspond with the descriptions on this site. Is that right?
    We had initially thought that the issue was the O2 sensor/s.
    After doing some reading on here, it would appear that it could simply be the fuel type, as we have been using 97RON rather than 99.
    Alternatively would the injectors be worth looking at ahead of the O2 sensors?
    Any input would be greatly appreciated.
    Stu
    Jun 2011
    Great Melton Norfolk
    1,340
    coil packs?
    try some injector cleaner or octane booster through it.
    May 2009
    11
    Are you thinking coil packs because of the combustion failure?
    Administrators's Avatar
    Administrator
    Oxfordshire
    1,000,001,883
    Follow Administrators On Twitter
    I would be looking to change the EGT and the airmass. The EGT are a common problem and the airmass will give you the lean running. Clear the codes and see how it goes from there. I wouldn't do anything else untill those were done.
    A
    16684 P0300 Random/Multiple Cylinder Misfire Detected
    16686 P0302 Cyl.2 Misfire Detected
    16690 P0306 Cyl.6 Misfire Detected
    17867
    P1459 Exhaust gas temperature sensor 2 range/performance
    17544
    P1136 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
    17546
    P1138 Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
    May 2009
    11
    Thanks for the reply.
    The codes were cleared on Friday and the EML has not come on again since. When is was last reset it came on again the next day, so not much in the way of consistency.
    EGT = Exhaust gas temperature, yes?
    Am I right in saying that they are sensors between the downpipe and the turbo? (from other posts)
    Administrator
    Oxfordshire
    1,000,001,883
    Hi StuC
    The EGT is on the other side of the turbo and bolts into the manifold flange of the turbo. They have to be fitted from above.
    Best of luck
    A
  1. Definitive list of engine codes
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2009, 20:52
  2. quick engine code question
    By paulwakinshaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2005, 12:05
  3. A4 Intercooler Differences with engine code
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2005, 16:58
  4. Engine code AMU
    By ANDYTQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2004, 09:02
  5. Engine Code for Polo GTi
    By chuffer in forum Volkswagen and other VAG
    Last Post: 12th October 2004, 12:09
