Volks AutosMonster Motorsport
Results 1 to 13 of 13
    Aug 2012
    Immobiliser Instrument Cluster Key Coding
    New here, hello!
    Well, I had the dreaded missing lines on my 2001 A6 2.5 TDi Quattro display and thought I would repair it myself. Long story short, the cluster is now damaged beyond repair so I am getting a replacement from a breaker.
    So, can I get the immo and mileage reprogrammed?
    Do I need to go to a Audi Dealer?
    Is it easy?
    Is anyone in the Lincoln/Boston/Grantham area able to do this with a VAG-COM?
    Also, I have a 2 remote keys. One works, one doesn't despite new batteries. Is it common for these to need reprogramming if left flat for a while?
    Any help gratefuly received.
    Thanks.
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    280
    Add craigynett on Google+
    you don't need to go to the dealer. You need somebody with VCDS/Vagcom. I've not done it myself yet but i'm sure there's a guide on the ross-tech wiki page. I'm sure somebody said you need to read the pin code from both clusters so that you can program your replacement cluster to have the same pin code as original cluster.
    As i said, i haven't done it myself so don't quote me on it. In fact i think there's a guide on ukmkiv golf forum
    As for your remote. It needs testing with an RF tester to make sure it's still sending a signal, if it is then it prob just needs to be resync'd with the car
    Craig
    Please contact Admin if you wish to advertise your business/services on the forum
    Mar 2012
    221
    Quote Originally Posted by craigynett View Post
    Craig
    If you have Immoboliser III then you will almost certainly need a Pin code from the new cluster and the Pin code from your ECU.
    VCDS/Vag Com will not pull these (too easy for crooks). The supplier of the new/replacement unit should provide one and a car locksmith/mobile key recoder will be able to lift your current Pin.
    Immobilizer III Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
    Immo II 'may' need the Pin as well...
    Immobilizer II Immobilizer Swapping (Instrument Cluster) - Ross-Tech Wiki
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    Easiest thing to do is obtain another cluster and get the key fob that came with the car with the immobilizer transponder, this way using VCDS you can match the ECU to the new cluster and key (it's the equivalent of doing an ECU swap with VCDS) I've done this on my Immo II A6 many times. This way you don't have to get the PIN or the SKC code.
    Mar 2012
    221
    Quote Originally Posted by evomaster3000 View Post
    Ahhh Audi thought of that you will need to PIN code the Injection Pump ECU!
    Aug 2012
    Thanks guys for all your help!
    Just to let you know, I sent the cluster to CARTRONIX and they were able to fix it. I was so pleased not to have the immo issue and they turned it round very quickly. Well worth the money for a great reliable service so a thumbs up from me.
    As for the fob, it was dead so I had to buy a replacement. Worth it though as the car is lovely!
    Thanks again.
    Dec 2004
    Bristol
    449
    Quote Originally Posted by TYphoon GB View Post
    Really? I've not had any issues on my 1998 C5 A6 AFN (non PD).
    Mar 2012
    221
    If its a Bosch VP44 it needs PIN coding for a change in pump or immobiliser.
    Immobilizer III Injection Pump Swapping - Ross-Tech Wiki
    Dec 2004
    Bristol
    449
    I see, Mine is a 1.9 TDi, therefore a Bosch VP37 iirc? and I've got Immo II (early C5), either/both may explain this.
    Mar 2012
    221
    Yup 2.5 Immo III you lucky person!
    May 2012
    RETFORD, NOTTS
    1,707
    I wish i had seen this sooner. I was able to retrieve the pin from my partners car without too much drama. Now just need to find a cluster !
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Rune Korneliussen's Avatar
    Quattro
    Jun 2012
    Norway
    9
    I did the key in the ignition and turn the other key in the front door.
    Does that just code it so i can open the doors?
    98' Audi A6 2.4 V6 Quattro
    Mar 2012
    221
    I understand that if you have good key then yes that works. If you have no good key then its programmer and PIN time.
    The key has a Radio Frequency ID tag inside so all you are doing is matching the keys.
    If you swap hardware (keys, pump, dash etc) then the main immobiliser control module in the dash pod is the master PIN.
    More here.... Immobilizer - Ross-Tech Wiki
  1. INSTRUMENT CLUSTER
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th November 2006, 11:40
  2. Changing the instrument cluster on an S3
    By jgrand in forum General Technical / How To
    Last Post: 17th June 2004, 13:38
  3. A4 instrument cluster problems........ common?
    By dachtor in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2003, 01:34
  4. A4 KEY CODE PROBLEM
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th June 2003, 18:13
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
