Monster MotorsportVolks Autos
    Mar 2012
    227
    Timing the 2.5 TDI - A few questions.
    Having thought I had done a good job on setting up the dynamic timing I began to suspect myself.
    Using the TDI graph was driving me mad so I have resorted to the Vag Com section Engine, Measuring Block, Group 0 numbers 2 & 9
    At 160 Temp I am getting 60 which is a bit advanced but in range.
    Much messing with the pully told me that this was time to stop.
    Runs fine but cold starting is 'not perfect' almost goes for a few seconds like its building up and then vroom.
    Today I tried the 'other method'
    Using Group 004
    Ran like a nail and the numbers looked bad.
    Does this work for the BDG Motor?
    Anyway monitored the timing from cold using Group 0 again and it started at 85 and slowly dropped to 60 as it got to temperature.
    My questions..... Is the ECU taking the slack and working overtime for the timing being advanced?
    If I get 60 then it looks good...is it?
    Or is it normal?
    Jul 2007
    London
    3,090
    Use the basic settings block4 and pull the v6 tdi block from the drop down box, should show if it's advanced or retarded- only if you have the fully registered version !
    FOR SALE:
    Mar 2012
    227
    Its advanced just a bit...but in the band.
    Guess the starting issue is something else ...but it has been standing for a while.
    Would reducing the EGR help starting? Just something I saw on the Ross Tech site....
    Jul 2007
    London
    3,090
    if it's in the band then the only thing i could think of is air in the fuel lines. Have you changed the plastic tee valve on the fuel filter ?
    FOR SALE:
    Mar 2012
    227
    Quote Originally Posted by adamss24 View Post
    Nope....will now ....cheers!
    Mar 2012
    227
    Neglected to close.....That worked...thanks!
  1. Just bought 2yr old A4 2.0 TDi Multitronic... few questions to ask
    By sid812 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th June 2011, 09:30
  2. few questions on the 1.9 tdi 130bhp
    By K7ERG in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2011, 12:50
  3. time to uprate tdi... few questions!
    By Matt_ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th March 2010, 20:29
  4. Buying a A3 Sline TDI soon. Few questions...
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2006, 20:36
  5. newbie here with a few questions about the a4
    By imported_Emilie in forum The Welcome Section
    Last Post: 7th September 2004, 07:56
