Sky InsuranceVolks Autos
Results 1 to 7 of 7
    Mar 2012
    Doncaster
    66
    A6 2.5tdi egr removal?
    Hi is it worth blanking off the egr valve with just a plate or should I get a bypass kit or just not bother I've had it stage 1 remapped
    Ian
    Jan 2012
    teeside
    45
    I blanked my eye of with q plate from eBay. I found the car more responsive and as yet no probs.
    Mar 2012
    Doncaster
    66
    Cheers I'll order one
    myth's Avatar
    Dec 2012
    90
    I plan to shut off my EGR too on my 2.5 tdi and for that, I have 2 types of questions:
    1. What are the drawbacks? What about the advantages?
    2. How should I remove it? Simply block the vacuum line, or buy blocking plates?
    Nov 2012
    6
    downside....NOx emissions go up, polar bears die. ecu Might get a bit confused and order up a derate, but probably not on a euro3 engine.
    plus side... better fuel econ and performance
    myth's Avatar
    Dec 2012
    90
    So, I don't care about the NOx emissions. The engine is euro2. So I should go ahead and do it?
    How it's best to do it:
    a) physical remove
    b) remove via vag
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    274
    Just blank it off at both ends, should need to map it out, being e2.
    plates available on ebay, gaskets from TPS. shouldnt cost any more than £10. Dont forget to blank off vacuum hose which goes to EGR valve.
  1. EGR removal on a 2.5tdi
    By VagCabby in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2013, 21:34
  2. A6 2.5tdi egr blank or removal bkc engine
    By Ianb4310 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th July 2012, 13:12
  3. 2.5TDi Turbo removal - can anyone advise??
    By Chrisavant in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2010, 21:57
  4. 1.9 TDI 110 EGR REMOVE??..
    By Keithsri in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th April 2010, 21:55
  5. EGR Removal Isit Worth it
    By StompOn in forum Diesel forum
    Last Post: 26th April 2009, 21:46
