AH FabricationsSky Insurance
    Mar 2012
    Doncaster
    66
    A6 2.5tdi egr blank or removal bkc engine
    As the title says I'm interested in blanking off or removing the egr valve from my 2002 A6 2.5 tdi has anyone done this ?
    Is it easy are there any "how to" on here been searching but not found any
    Any help please
    Ian
    Jan 2012
    teeside
    45
    I have a 2000 2.5tdi. I blanked mine of and it took around 10 mins. Just removed the engine cover off, removed the 2 bolts from the egr valve which loacte the pipe to valve, slipped in plate then reversed procedure.
    Mar 2012
    Doncaster
    66
    Cheers I'll order one
    Jun 2012
    6
    What's this? I could google but what's a forum for if u can't ask a question. Lol.
    Dec 2010
    Wellington, Somerset
    107
    I am considering this too. Please can you explain what the advantages are of doing so & if there are any disadvantages. I would espcially like to increase my mpg - does it do this? My car is 2.5 V6 Tdi 2004 A6 Allroad (BAU engine). Is the increase in running temperature of the engine an issue?
    seems v easy to do, saw a picture of how to do it on one of the listings on ebay for the blanking plates, simply loosen the 2 hex bolts on end of pipe leading to EGR valve and slip in the blanking plate (it has slots so it can slip in rather than having to remove anything).
    Jul 2007
    London
    3,252
    Quote Originally Posted by ms1083 View Post
    Your's will flag an emission related code and it will put the engine management light on the dash. Your's need the EGR settings deleted in the tune so a remap is the way forward !
    FOR SALE:
  1. Performance probs after fitting EGR blanking plates
    By tuffguy in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th June 2014, 22:52
  2. EGR blanking plate size 2.5tdi
    By nanafagis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2011, 11:25
  3. Audi A4 1.9tdi EGR blanked and Inlet Cleaned
    By craigg9700 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2011, 22:12
  4. egr blanking
    By r3stu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2010, 22:43
  5. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
