Chris NottJMB Retrofits
    imported_christhick
    calling all 2.8 V6 owners
    Have any of you guys ever had your engines flood and refuse to restart. This has happened to me 4 or 5 times now.
    The solution is to take the fuel pump fuse out and turn the engine over a few times before putting the fuse back in. Apparently there is a fuel reservoir that fills up and acts as a sort of choke. However, this and the fuel pump acting together can flood the engine.
    Does anyone know how to stop the problem or if it’s a common fault with this engine?
    28v6
    Re: calling all 2.8 V6 owners
    Yep! change the fuel regulator thats yer revoir that you refer to, usually located on the fuel rail somewhere...looks small and cylindrical...
    imported_christhick
    Thanks for the advice, although the A4 boys are saying its the temp coolant sensor? could that also be a possibility?
    Aug 2005
    Tampa,Florida
    I've got the same issue and it's a problem w/ the coolant temp sensor. It's telling the engine that it is cold so it makes it go rich by increasing the "cycle on" time of the injectors. I've also got a MIL on and off w/ faults for the temp sensor. I'm replacing it tomorrow. Will let you know if my theory is correct. Usually a sensor sending a cold signal when the engine is actually cold is not a problem, since it takes more fuel to start a cold engine. But when the engine is hot it will flood the engine and cause it not to restart. Also, another symptom of this issue is, if you hold the starter on and it DOES finally start, you will see lots of black smoke come out the back.
    -Brian
    imported_christhick
    Got mine fixed not long ago. It was the temp sensor. The car performed faultlessly after that.
    Cheersi
    Chris
    Jun 2004
    27
    I had the problem on a A4 2.4.
    (The temp sender didn't show warm when the engine was tho....)
    see
    http://www.audiworld.com/tech/eng54.shtml
