AH FabricationsVolks Autos
    Jun 2012
    Unhappy Allroad Plenum Chamber
    Hello,
    With all of the rain we had in April, my A6 allroad flooded. It has a full audi service history and has only don 41k. Audi Watford have inspected the car and have said that it has £3500.00 of repairs needed! They've said that the plenum chamber filled up and overflowed into the EC unit, which then overflowed into the cabin of the car flooding under the drivers seat and wrecking the ABS system and anything else thats placed under the seat.
    I can not believe that this could be caused by rain!!!!
    Has anyone else had this problem?
    Audi head office are taking no resposibility as they've said the car is over 5 years old.
    Totally gutted and I would never purchase another Audi if this is a common fault.
    Dec 2010
    Wellington, Somerset
    100
    My initial thoughts:
    ensuring the phleum chamber drains are not clogged/the chamber clear of leaves etc is part of the standard service - was it servied recently? If so, maybe the garage failed to check this? but if you park under trees it may clog up quite quickly. Other cars can have this problem too, my mondeo did it and also an old fiesta - luckily neither of these have so much electronics hidden in the footwells so all was ok.
    Sometimes electronics are ok again when they dry out, it takes ages for a car to dry, worth taking out the seates, pulling carpet to help dry it out.
    If not consider advice from an audi independent and maybe get spare parts from scrap yard or look into getting yours refurbished. Only problem is most of these items require syncronising with the car so you would need VCDS.
    Can audi guarantee if they replace all the parts they say will it all be ok? there might be more damage they can't find at this stage or will show themselves as metal connections corrode over time.
    Aug 2010
    1,540
    you should always check these drains yourself. it takes just a few seconds. have a look round the battery see if you can see standing water. if not get a watering can and pour some water in there.... if you can almost immediatly see the water running out from under the car then the drains are fine.
    audi advise the drain hole rubber bungs be removed to unsure they cant get blocked up.... so if its been into audi for a service and they havnt been removed..... you could argue that they should have been as part of the service?
  1. Plenum Chamber Drain Grommets - Every A4 B6 owner is affected by this common fault
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th July 2012, 21:04
  2. Plenum chamber bungs
    By Rhencullen1989 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th July 2011, 07:20
  3. Audi A6 C5 - check your plenum chamber - mine was full of water
    By Alski2009 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd January 2011, 00:34
  4. allroad tyres? - UK
    By hirsty in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd June 2004, 15:07
  5. Allroad lowering kit (chip?)
    By DaveP in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th October 2003, 20:34
