Sky InsuranceChris Nott
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    Question Syncronising remotes A6 C5 help
    Hi, on a friends A6 allroad, both remotes have stopped working, I have had this on my A6, I found an online instruction which involved pressing the lock or unlock buttons 1 time for remote 1 and 2 times for remote 2. I cant find these again. can any one help?
    Much appriciated.
    Wes
    Mar 2012
    244
    Found this .... Not sure this works on Immob' III vehicles...
    Programming new remote controls
    Two keys and all the remote controls that are to be programmed
    will be needed. The maximum number of remote controls that can be
    programmed, including old and new, is four.
    - Insert first key into ignition switch, and turn it to
    "ignition on."
    - Insert second key into outer door handle, and turn it to
    unlocked position for 10 seconds.
    System alarm will emit three beeps.
    - Take first remote control to be programmed and press button
    -1-, two beeps will be emitted. For second remote control, press
    button -1-, two beeps will be emitted. Use same procedure to program
    third or fourth remote control. All remote controls must be programmed
    within one minute, otherwise new programming will cancel and old
    remote control programming will be valid.
    - Turn key in outer door handle to unlocked position for 10
    seconds, one beep will be emitted.
    - Switch ignition off
    wesmaster's Avatar
    Apr 2012
    Oxfordshire
    291
    I'll try this tomorrow.
    thanks.
    Wes
  1. Remote central locking. HELP
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2011, 15:10
  2. 2003 Audi a3 2.0,remote fob problems?? help please
    By Mcblow in forum General Technical / How To
    Last Post: 29th June 2010, 20:43
  3. audi a3 1.6 sport 1998 remote key please help
    By rorangina in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th February 2010, 08:14
  4. Problems with remote locking/alarm, help
    By evomaster3000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th August 2008, 15:14
  5. Help with vagparts remote locking kit?
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th July 2004, 09:00
