Results 1 to 8 of 8
    nay
    Mar 2012
    7
    urgent help please
    my 2.5 tdi isnt getting fuel as far as the front fuel pump, iv had the inspection plate off from under the seat and its primeing...my question is....DOES THE FUEL PUMP ACTUALLY PUMP FUEL FROM THE BACK TO THE FRONT OF THE CAR OR JUST FILL THE SWIRL POT UP...we are getting nothing at the filter...
    Mar 2012
    244
    Warning....
    From my recent and limited experience....
    Here goes...
    The pump is pretty pathetic and needs priming...
    The injection pump is also pretty weak and prone to failure at high mileage also need priming.
    To check the pump (in the tank) put 12v across the fuel pump fuse (think its no 28 but its clearly indicated on the fuse panel as fuel pump)
    Avoid using the lighter socket power as the pump has a higher current rating, a cable to the battery live worked for me.
    nay
    Mar 2012
    7
    Quote Originally Posted by TYphoon GB View Post
    Warning....
    Here goes...
    with the cover off i can hear thr pump in the tank...with the pipe of should it be sqirting fuel everywhere?
    Mar 2012
    244
    apparently not...seems to rely on the injector pump pulling it through..
    HerefordQuattro's Avatar
    Hereford
    303
    Correct the pump in tank only feeds diesel from the bottom of tank to a baffle. The main engine pump then pulls fuel from the tank baffle via the filter
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Mar 2012
    244
    Quote Originally Posted by HerefordQuattro View Post
    Learning he is...slowly....
    Hereford
    303
    The path of the V6Tdi is long young padawan...
    and I've had very recent practice when it took me 3 days to get it to start after a fuel filter change!
    nay
    Mar 2012
    7
    well i replaced the pump in the tank as everything was pointing to that and it worked..all fine now
  1. PB team need urgent help - please read!!!
    By WX51TXR in forum Detailing
    Last Post: 18th July 2007, 15:19
  2. Urgent Help Please
    By dentsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2007, 15:52
  3. URGENT HELP PLEASE - CAR IN BITS AND GETTING DARK!!
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2006, 22:13
  4. URGENT HELP please
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 22:42
  5. URGENT Help Please
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 17:06
