Badger5EM Tuning
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 84
  1. #41
    May 2012
    63
    Quote Originally Posted by a6_chris View Post
    Right, from reading different articles online, i think he might have bluetooth.
    get him to take the cradle off and it should see a few metal contacts when this is removed.
    now start the car and press TEL, it should say search for telephone or something similar .. try this
    sorry, there is no cradle with the car but the plate is there with the contacts showing. Looks like you can clip any cradle in to match a particular phone you have. I'm sure blurtooth is not highlighted in the slection menu. I'm not sure now or its there but when you try to select it it says its not availale or something
  3. #42
    Jan 2012
    1,837
    Ah if it says not avaliable then it works off the cradle
    just get him to buy a compatible cradle for his phone and for his mmi.
  4. #43
    May 2012
    63
    he has an I-Phone. how much are the cradles? do you have to get them from AUdi?
  5. #44
    Jan 2012
    1,837
    New they're around £90, can source them from eBay, doesn't have to be from Audi.
    Take this as an example Audi bluetooth cradle for iPhone 3G/3GS/4/4S | eBay
    and this .. bit cheaper Genuine Audi Apple Iphone Cradle 8P0 051 435 GP | eBay
  6. #45
    May 2012
    63
    thanks
    They are both on auction so they might end up around £90. They are both the same so I'll see what sort of money they go for.
    Looks like not much of a shopping list
    For me
    Battery Monitor re-enabled
    Beep on Lock enabled
    for him
    I-Phone Cradle
    I've already done the 5570 MMI Update along with the 2102 maps. I'm doing his tomorrow so I'll see if he looses the battery monitor as well.
  7. #46
    Jan 2012
    1,837
    Thats all we can do on MMI 2G - Suppose the technology wasn't there before the facelift cars to do more stuff like i said above
    Ok, sure let me know tomorrow if it disappears and i will get the info sorted tomorrow morning/afternoon for you.
  8. #47
    May 2012
    63
    I wish Gary3306 had kept replying, he was keen to help but then went quiet. He is only 3 miles from me with VagCom
  9. #48
    Jan 2012
    1,837
    No problemo
    Check his page and see when he was last online - i would send him a friendly reminder incase hes forgot
  10. #49
    May 2012
    63
    a6_chris
    Managed to get in touch with gary3306, provisionally arranged for wednesday night for him to assist with the VAGCOM. Did my sons A6 5570 update and it went sweet as can be, only ran disc 2 once and it didn't seem to take as long as mine. He still has the battery monitor so he hasn't lost anything. If anything he has gained bluetooth by the looks of things. He has the cradle plate in the armrest but I'm sure bluetooth was not in the MMI before I updated. Anyway, chris. Is it possible for you to give some basic instructions on how to enable the hidden menu and to enable the battery monitor and bleep on lock as gary says he is not up to speed with A6's. Will the hidden menu be accessable all the time from then on without the use of a VAGCOM?
    thanks
    Mick.
  11. #50
    Jan 2012
    1,837
    Will get step by step instructions after dinner
    If he presses TEL what does the screen display now?
    Yep, it can be accessed all the time unless you disable it again
  12. #51
    May 2012
    63
    It says your telephone may not be connected properly BUT if you then go into settings there are options to set up the bluetooth which I'm sure were not there before. Thats good news about the hidden menu, will I then be able to enable / disable things as I want? what was the bootlogger or something you told me to keep away from?
  13. #52
    Jan 2012
    1,837
    Press TEL, then Setup then there should be more options there.
    It was Bootloader .. Whatever you do, don't touch it or even look at it as your MMI will become in-operable
  14. #53
    Jan 2012
    1,837
    I didn't realise I left my VCDS lead in the A3, which is away until 6.30 -7pm so will do then.
  15. #54
    May 2012
    63
    No problem Just when you have the time
    Thanks again
  16. #55
    Jan 2012
    1,837
    Hidden Menu
    Module (07) Control Head
    Adaption
    1) Channel 008 - Change saved value to 1 - Test then Save
    2)Channel 111 - Change saved value to 1 (MMI will now restart)
    Bleep on Lock
    Module (46) Comfort System
    Coding
    1) Add 2048 to the current value -- EXAMPLE: Current value 123456 + Bleep on lock = 2048 .. New value = 125504
    Press Do It
    Battery Meter
    Hold Car + Setup together for about 5 seconds - it may take you a couple of times to get the timing right - the screen should turn green
    Now scroll to Diag Settings and enter
    Now scroll to Car Menus Maske and enter
    Find the Battery Level and press enter
    Now scroll to the bottom and press Accept Changes
    Press Return 3 times to get out of Hidden Menu
    Reboot MMI by holding SETUP + MMI Central Knob + Inner top right button all together, the MMI should now restart
    When it reboots now press CAR and you will find the battery meter present.
    You can also change your MMI Startup screen to display S6 or RS6 .. I can provide the coding for these too.
  17. #56
    May 2012
    63
    Thanks for that chris. I'll print it off and take it with me when I go to see Gary. I hope he knows what it means cause it means nothing to me.
    thanks again
    Mick
  18. #57
    Jan 2012
    1,837
    It'll make sense when you see it .. Promise!
  19. #58
    May 2012
    63
    chris
    is there no channel number for the beep on lock? is there only the 1 item in coding to add the value to?
  20. #59
    Jan 2012
    1,837
    Nope when you press Coding - You will be given a value of what your car is currently at - just add 2048 onto that number and press Do It
    Channel's are only for when using the Adaption button.
  21. #60
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    Quote Originally Posted by coach View Post
    ....... I hope he knows what it means cause it means nothing to me.
    thanks again
    Mick
    Yes! I know what it means lol
    A4 S-Line. Mods so far; Cruise, DIS, Mk2 RNS-e, Audi 6 CD changer, XcarLink with self manufactured permanent ipod dock, B8 MFSW, Dectane Dayline Headlights with independantly switched DRL's, RS4 Rear ARB, De-badged, RS4 pedals, HIDS, RS4 front grille and RS4 style fog surrounds, LCR splitter in Satin Black, Rear Park Assist, LED gearknob, Red footwell lighting, Kitchen sink and Shower cubicle.
  22. #61
    Jan 2012
    1,837
    Quote Originally Posted by gary3306 View Post
    It's all up there Gary .. Any problems let me know
  23. #62
    gary3306's Avatar
    Oct 2010
    Northumberland
    950
    There won't be any problems mate. All the procedures are pretty straight forward
    Mark, I'll explain to you on Wed night what the coding is for. Its basically all to do with binary numbers. The decimal numbers we enter as coding are interpreted as binary numbers by the cars software. '0' means off, '1' means on. just like the switch on your kettle All will be revealed on wednesday night.
  24. #63
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    Battery Meter
    So is the car + set up menu the part you are referring too as the hidden menu that needs activating.
    Just wondering as on my 07 le-mans there was no battery meter before i updated the firmware or after and unless my timing is shot I cannot get that menu to appear.
    V8 baby... oh yeah
  25. #64
    Jan 2012
    1,837
    Yes you will need to enable it in vcds first then you can use the CAR+SETUP to access it
  26. #65
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    by the sound of what u can do for the a6 its not worth bothering with lol.
    V8 baby... oh yeah
  27. #66
    Jan 2012
    1,837
    Not really More functionality on the facelift cars with MMI3G
  28. #67
    May 2012
    63
    My son has a 07 S-line and he has the Battery Monitor. It wa s there before I updated to 5570 and it was still there after it. Not sure why I dont have it, I will on Wenesday night. My son never had MMI Bluetooth or voice recognition before the upgrade but he does now.
  29. #68
    Jan 2012
    1,837
    So when he presses TEL then SETUP it allows him to search for mobiles?
  30. #69
    May 2012
    63
    NO. He used his I-phone to find the car bluetooth and it works fine through the MMI
  31. #70
    Jan 2012
    1,837
    Awesome .. no need for the expensive cradle then
  32. #71
    May 2012
    63
    NO, he can access his phonebook from the MMI and everything
  33. #72
    Jan 2012
    1,837
    Yeah, he doesn't need the cradle then .. Please don't shout
  34. #73
    May 2012
    63
    Shout?
  35. #74
    Jan 2012
    1,837
    Forum lingo - caps = shouting
    Doesn't matter though!
    Let me know how you get on on Wednesday
  36. #75
    Jan 2012
    1,837
    double post - ignore
  37. #76
    May 2012
    63
    Caps Shouting? I always write caps if its an abbreviation or its written like that in the book (sorry)
  38. #77
    Jan 2012
    1,837
    Doesn't matter - I can see this going around in circles!
  39. #78
    May 2012
    63
    Let me know how you get on on Wednesday [/QUOTE]
    Sorted. :-)
    Many thanks to a6_chris for supplying the info and Mucho Grassy Arse to gary3306 for carrying out the instructions. Top Bloke. I hope I can do a favor in return in the future.
    Thanks Guys
    By the way, What is all that stuff in the hidden menu???????????????????????????????????
  40. #79
    Jan 2012
    1,837
    Good job - enjoying the lock chirp and your battery meter?
    All that gubbins is just various checks to do if there is ever a fault, modifiying the heart of the MMI and whatnot. I just choose to ignore all that
  41. #80
    May 2012
    63
    There are loads of things in there that are ticked that i dont even think I have. Lane assist is one of them. I've drifted into another lane before and never heard any alarms going off. (unless I was really sound asleep)
  1. RNS-E DVD/SD missing from my car, best solution to replace?
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2011, 08:46
  2. Missing ABS ECU question
    By PJM_01 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2010, 14:35
  3. Data only simcard question.
    By jojo in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 1st April 2010, 23:54
  4. DIS showing ID3 data (not a question)
    By boggysv in forum In-Car Entertainment
    Last Post: 29th January 2008, 13:56
  5. Surging solution?
    By observer in forum General Technical / How To
    Last Post: 23rd April 2004, 14:19
