Volks AutosEM Tuning
Thread: DRL
    Mar 2012
    Doncaster
    66
    DRL
    Hi wanted to pick your brains,is it possible to install DRL onto the inside of my 2002 A6 headlights ? Do the 2002 A6 headlights come apart and re-assemble ?
    Ian
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    They can be split apart, they are bonded together, the glue can be softened with paint thinners. But it's a bit of a messy time consuming job. I've seen some on facelift B5 A4's use a hobb drill to cut the lens off nice and tidy, then re-seal it back on. The break is hidden behind the rubber seal bit.
    Mar 2012
    244
    Will separate with a heat gun or hold in a warm oven.
    Just take it slow
    Reseal with fish tank adhesive is suggested.
  1. DRL on my A3
    By stainpain in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2011, 12:12
  2. DRL
    By Albie in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 9th June 2010, 17:41
  3. A3 DRL Help
    By antonio87 in forum The Welcome Section
    Last Post: 8th February 2009, 22:07
  4. DRL on S3 8P
    By S3 Big Andy in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd September 2008, 09:59
