AH FabricationsEM Tuning
    Mar 2012
    Doncaster
    66
    What do I need to retrofit DIS to my A6
    Hi I have a 2002 a6 2.5tdi multitronic what do I need to retrofit the DIS to my car is it simply the instrument panel and the stalk ? Or are there any other items? Can I use a second hand set of clocks ive seen some on eBay
    Thanks in advance
    Ian
    evomaster3000's Avatar
    Dec 2004
    Bristol
    449
    I'm still in the process of doing a retro fit of DIS on my 1998 A6 C5.
    So far I have wired up the stalk controls, thats just a case of matching up the colours on a bit of harness from the stalk and the IC, I now need to find a consumption signal (for mpg, range ect), then I need to re-wire some of the signals from my 8pin connector to the 20 pin, outside temp, brake warning etc.
  1. DIS retrofit help.
    By JayMc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2011, 13:59
  2. A3 DIS Retrofit
    By kite in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2010, 19:33
  3. Retrofit DIS for A3
    By BlackQuat in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2010, 22:06
  4. DIS Retrofit-- OH Yes
    By gregormac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2009, 19:42
  5. Retrofit of DIS
    By Caesium in forum General Technical / How To
    Last Post: 18th January 2007, 17:56
