Badger5EM Tuning
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    a6 quattro camber adjustment?
    as im going for the euro look for my a6, i want to adjust my camber so that my alloys tuck right in to the arches when the coilovers go on, i can find a camber adjustment bolt for the front, but cant seem to find anything for the back? iv seen some shims, but they dont seem to fit quattro's.
    any one ever had any experience with this?
    Passat B5.5 tdi....... big plans to come
    Audi A3 8p motor way work horse
    Nissan Skyline r33 gts-t ..... my mid life crisis fun car
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    just seen on other sites that the rear camber can be adjusted using the existing parts, any one know how this is done?
    Oct 2009
    Preston
    88
    Outer bolts on the lower arms are on elliptical washers and it the camber can be adjusted on those, although not sure it would give the angle you would be looking for?
    Usually these are loosened and removed to swap shocks and springs - it allows you to drop lower arms low enough to remove shocks.
    HerefordQuattro's Avatar
    Hereford
    303
    And they're very often seized solid!
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    audi-a6's Avatar
    Aug 2011
    christchurch
    489
    they un-done quite easily, but no, did not get the camber that i wanted, want about another 1 degree i think, any sugestions?
  1. Camber adjustment??
    By floyd 1.8 turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th February 2012, 22:09
  2. Camber Adjustment
    By bench33 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th May 2011, 15:29
  3. Camber adjustment
    By smudge_don in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th May 2010, 22:44
  4. Replies: 6
    Last Post: 24th June 2009, 22:46
  5. camber adjustment
    By MOSSY in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2005, 18:08
