Monster MotorsportEM Tuning
    Jan 2012
    teeside
    45
    headlight washer (a6 2.5tdi quattro, 2000 plate)
    Feeling a bit sheepish as I realised my car has headlight popup washers . However they ain't popping up or washing. Have checked fuses that was neg, and have tried with headlights on as well which proved neg as well. Any pointers be appreciated.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Check the pump on the washer bottle. The washers pop up with the water pressure. If your bottle has low water the headlights washers won't work
    A4 (b6) 2.5 TDi QS Saloon.
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    882
    Quote Originally Posted by abdul h ghafoor View Post
    I had the same issue with my S3 that i recently bought. Wondered why they weren't working. My uncle (Motorsport mechanic) came round over the weekend and suddenly got them working, without any tools/diagnostic equipment.
    I did cop the way he operated the stalk though......he plipped the stalk once on, let off, then held up constantly so windscreen was spraying. I was stood at the front of the car at this point and saw the headlamp washers work with my very own eyes.
    Give that a try maybe?
    Jan 2012
    teeside
    45
    Well fixed the headlight washer. Had to access the washer bottle via the n/s front wheel arch. Took the inner cover out held by numerous torx head screws and two bolts. Once removed the washer bottle has two bold holding it underneath. Plus one bolt which u get via the engine bay. I found that the headlamp washer motor connector was loose and dirty. Quick clean and reconected and up they popped squirting away.
  1. Replies: 2
    Last Post: 28th February 2012, 10:52
  2. We got it, 02 plate - A4 B6 2.5tdi Quattro Avant
    By motosparkz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th September 2007, 21:28
  3. Newbie, hopefully buying a 52 plate 2.5tdi quattro
    Last Post: 22nd September 2007, 09:44
