Monster MotorsportBadger5
    Feb 2009
    Devon
    Water pump/viscus fan!
    Hi this is my 1st post... I was wondering if anyone else has had the same problem as me... I've got an Audi Allroad 2003 2.5tdi, my attention was drawn to the noise coming from under the bonnet and poor economy after taking it to the garage it appears that the fan does not disconnect after starting an is only permenantly. Has anyone else experienced this? If so how was it remedied? The only thing the garage could say was to replace both units at the same time as the timing belt
    Dec 2010
    Wellington, Somerset
    108
    Don't know about the fan - could it be a sensor rather than replacment needed? Did the garage do a full fault code check?
    However, if the timing belts get replaced definatly replace water pump at same time as they tend to go and the belts have to come off the get access and timing belt change itself is a rather big job. Also change tensioners/idlers etc.
    Jul 2007
    770
    Is the fan making the noise?You s/b able to stop it by holding a rolled up newspaper against it .Mine was replaced when the belts were done
  1. Audi A4 'Water Pistol' to VW Passat 'Fan Jet' Conversion....
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th November 2013, 09:08
  2. What type washer jets have you got? water pistol or fan spray?
    By sulaiman in forum General Automotive Chat
    Last Post: 4th October 2011, 14:07
  3. Water pump
    By os360 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2008, 19:38
  4. Water pump
    By johnie72 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2007, 21:41
  5. Water Pump on a 97 A3?????
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2004, 09:16
