AH FabricationsChris Nott
    Feb 2012
    Engine speed sensor location 2004 2.5 TDi?
    Can anyone help? Drove the car home on Thursday night & it wouldn't start in the morning!
    The car has only covered 60k & was previously running fine, DTC logged as Engine Speed Sensor G28 so I'v ebought a new one just in case but can't find it on the engine! Did a search on here but no luck as yet either
    Feb 2012
    Ok after much looking & now having the new part in my hands I've found it but can't see any way you can get to it & change it!!
    Jul 2007
    London
    3,070
    There's 2 speed sensors in the v6 tdi, one is also known as the crank sensor, the other is built inside the VP44 injector pump. the crank sensor can be replaced- fiddly but doable, the one inside the pump needs a pump rebuild ! I suggest you check the engine with VCDS, measuring blocks 18 to see if the pump controller gets power. If it gets then replace the crank sensor, if it doesn't then the pump will need a rebuild. I take it you have plenty fuel ?
    FOR SALE:
  1. Coolant temp sensor location on 2.0 tdi BLB engine code
    By polo10v in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 5th March 2013, 20:43
  2. engine speed sensor
    By jimes in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2010, 11:18
  3. engine speed sensor
    By S3SYD in forum General Technical / How To
    Last Post: 1st May 2008, 22:46
  4. Hello - engine speed sensor
    By K12_RNS in forum The Welcome Section
    Last Post: 7th October 2007, 16:16
  5. A3 Engine Speed Sensor
    By K12_RNS in forum General Technical / How To
    Last Post: 2nd October 2007, 01:02
