Chris NottEM Tuning
    Feb 2012
    Audi A6 C5 Single to Double DIN Conversion
    Hey Audi Fam!
    Im new to this forum, so I would like to say hi to you all. I have a few questions about converting your audio from single DIN to double DIN. I know there is a fair bit of info out there, but a lot of it seems American, totally different or contradictory.
    I have a 2001 Audi A6 Avant with a single DIN Concert II radio. I recently bough a Navigation Plus 4B0035192K double din Sat Nav unit from a chap who has the same age Audi A6 as me so hopefully it will be compatible (no wires or antenna though). I realise I need a double din cage but need clarification on a couple of other issues:
    Will I need an additional wireing harness or will it just plug in and play?
    Will my Climate Control still fit or can it be modified to fit once the double din unit is in - or will I need a double DIN one?
    Will I need a double DIN type ashtray also?
    Will I need to change the panel above my stereo i.e Cup Holder, ESP and Hazards.
    I realise you have to take the panel under the steering wheel and glove box off - is this to so you can remove the single DIN cage?
    Any help/advice/things to watch out for - at all you can give me would be great. If you have any links to share with a walk through guide that would be amazing. I realise this isn't going to be an easy job, but I want all the pieces in place before I dismantle my beloved car!
    za6
    Feb 2012
    Hi guys! Just installed double din cage in to my A6 C5. And I get problem with wiring.
    I need wiring diagram or even pictures is will be good for upgrading from concert 1 to RNS-D nav plus.
    Is the anyone can help me with this?
    Many many thanks!
    Jul 2007
    London
    3,072
    Just go to the kufatec.de website and look for the right adaptor...They do the wiring for audi so they are as good as the originals !
    FOR SALE:
    Mar 2007
    23
    there is adaptor on ebay.de for few euros.
  1. ANYONE HELP?? Head Unit - Single Din to Double Din Conversion
    By rdhighoctane in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2013, 23:03
  2. HELP PLEASE?? Single Din to Double Din conversion..
    Last Post: 10th October 2011, 16:47
  3. Conversion from Single Din to Double Din - facelift
    By influxsg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th November 2010, 18:15
  4. single din to double din conversion
    By jazzy_a4 in forum In-Car Entertainment
    Last Post: 14th March 2010, 15:13
  5. Nav+ and Bluetooth Retrofit: single-DIN to double-DIN conversion
    By jesters3 in forum In-Car Entertainment
    Last Post: 14th May 2008, 13:12
