    brasiliangringo's Avatar
    Mar 2010
    538
    Constant outside air temperature displayed in dash
    The ambient temperature display measures a fixed 78-79Farenheit & never changes. I have used VAG Com and there are no error codes reported on the outside temp sensor which is positioned behind the front bumper. I also unplugged it at the 'plug end'(fairly sure it was the right plug - passenger side under and next to small filler tank - hydraulics) and the dash ambient temp reading remained the same ie 78F - even with the sensor disconnected ?! Yes, it is a UK car, so not sure why its not in C.
    Should also add the dash has a faulty water temp gauge which is a cluster issue..
    Any ideas?
    2000 c5 A6 Avant 2.4
    Aug 2009
    197
    Assume the air con displays are also in F. To switch to C
    Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
    As to why the temp is stuck can't help you on that, may be related to the cluster issue
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
  1. Dash temperature gauge issue.
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2009, 22:01
  2. Constant hot air through blowers....
    By christinho in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2008, 18:48
  3. Audi 1.8T AEB engine oil light displayed on dash.
    By K7ERG in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2008, 16:45
  4. Temperature sender for dash temp gauge
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th March 2006, 19:36
  5. 2001 A4 Outside Air Temperature eratic
    By imported_ptm in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th June 2004, 23:50
