Badger5Sky Insurance
    Nov 2008
    35
    Clearing fault sign on dash display on A6 Avant 2001
    Hello
    I have just changed my water temp sensor on my car, I have disconnected the battery,but that didn't clear the dash warning light.
    Audi want to charge me £75 for half an hours labour to clear it !!!!!!!!!!
    Any one know another way to clear it?
    Kevin
    AUDI A6 AVANT 2001 QUATTRO 4.2 V8
    kite's Avatar
    Oct 2007
    East Berks
    675
    Look in the vagcom section for a member in your area to clear the light for you
    A4 (b6) 2.5 TDi QS Saloon.
    Jan 2012
    48
    You may find that the fault indication clears itself after a few starts of the car. I had a similar issue when I disconnected the MAF on my car to replace the headlamp buld as this brought up a fault.
    Failing that just about any garage with the right kit should be able to clear it a lot cheaper than £75, i know my local garage charges £25 for a full scan of faults, a print out of the faults and reseting of any fault indications that are no longer valid.
  1. How to drive after clearing any engine fault codes? Like you stole it?
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2011, 16:54
  2. Door open sign on dash
    By audi lover in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2010, 12:45
  3. Help on mpg dash read out display updated with fault
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2009, 22:27
  4. Clearing fault codes
    By mitch78 in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th July 2008, 01:32
  5. low oil dash warning light not clearing!
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th March 2008, 12:53
