Sky InsuranceVolks Autos
    Jan 2012
    Yorkshire
    Glowplugs 2.5TDi v6
    Can anyone tell me what glowplugs I need for my 2002 2.5TDi v6 (155) please?
    Dec 2010
    Wellington, Somerset
    103
    Quote Originally Posted by 2sprintfast View Post
    Well worth replacing them. I did mine last year (2004 2.5tdi V6 allroad). 5 out of 6 of them were totally dead and did nothing when connected up to spare battery! Car was starting fine before but really fires up now! 1 of them was a total pain to get to, didn't have to remove anything to improve access but loads and loads of tiny turns with the socket set to unscrew it, can't remember which it was now, I think it was one of the ones nearer the front on the right - and it turned out to be the only 1 that didnt need changing!
    you can find which ones to get on eurocarparts.com they are about £12 each there. I acutally bought some bosch ones off ebay for a bit less about £40 for all 6 I think, no problem finding the right ones.
    Below is a copy off ELSA with details on how to change them:
    Removing and installing glow plugs
    Special tools and workshop equipment required
    t U/J extension and socket, 10 mm -3220-
    Removing
    Switch off ignition.
    Detach glow plug connectors from glow plugs.
    Clean glow plug openings in cylinder head; make sure no dirt gets into cylinder.
    [IMG]file:///C:/ElsaWin/html/images/hinweis.gif[/IMG] Note
    t Cleaning procedure:
    t Use a vacuum cleaner to remove coarse dirt.
    t Spray brake cleaner or suitable cleaning agent into glow plug openings, let it work in briefly, and blow out with compressed air.
    t Then clean the glow plug openings using a cloth moistened with oil.
    [IMG]file:///C:/ElsaWin/graphics/wi/W00-0329.png[/IMG]
    To slacken the glow plugs use special tool U/J extension and socket, 10 mm -3220-
    Installing
    Before installing, coat threads of glow plugs with high-temperature paste → Parts catalogue, servicing materials.
    To tighten the glow plugs use special tool U/J extension and socket, 10 mm -3220- with a suitable torque wrench.
    Tightening torque: 18 Nm
    Attach glow plug connectors correctly and make sure they are securely fitted.
  1. 2.0TDI BKD glowplugs
    By zippyijk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2014, 11:54
  2. My 2.5tdi V6 :)
    By AudiAndy21 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th October 2011, 21:59
  3. a4 2.5tdi same engine as a6 2.5tdi help pls?????????????
    By davidfox280585 in forum General Automotive Chat
    Last Post: 1st May 2010, 19:12
  4. glowplugs?
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2009, 00:03
  5. Glowplugs
    By Ant33 in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th February 2008, 11:45
