Sky InsuranceJMB Retrofits
    Jan 2012
    A6 2.0 TFSI BPJ Oil Pump
    Hi everyone,
    Looking for advice on how to proceed with a repair.
    Oil pressure warning light came on not far from home. Stopped the car and switched off. Mechanic came to look at car and engine ran albeit rattling top end.
    Turns out the oil pump has disintegrated.
    My question, should I get the oil pump replaced and hope everything else is ok (stray bits of oil pump, further damage), which is seemingly impossible to predict
    OR
    do I get the engine refurbished to ensure everything will be ok.
    On a budget but obviously looking to keep the car for a while yet.
    Engine has 120k on it.
    Many thanks
    May 2006
    UK
    167
    buy oil pump and drain oil and cross fingers.....
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    Aug 2009
    198
    Might want to do two oil changes in quick succession (change the oil + filter, run the engine at idle for 20 mins or so and then change again) to ensure you get as much of the disintegrated pump out as possible. Given the high mileage of the engine probably best to avoid using a flushing oil. Could use a cheaper high street brand for the first change then revert to a quality oil, but best to stick with same type (i.e. if you have been using fully synthetic, then use same for both changes). Then of course cross your fingers, but if the engine remains (or becomes) noisy after this there is only one further course of action.
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
  1. 2.0 TFSI FUEL PUMP & FREE REVO
    By AwesomeMike in forum Awesome GTI
    Last Post: 24th January 2011, 12:29
  2. Oil - 2.0 TFSI
    By Sam W in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th January 2011, 16:39
  3. TFSI Fuel pump cam follower
    By KRL in forum Parts Requests
    Last Post: 2nd February 2010, 14:43
  4. A4 oil pump
    By yabba yabba in forum Parts Requests
    Last Post: 26th January 2010, 12:23
  5. Upgraded fuel pump internals for 2.0 TFSi
    By TheWusMan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2008, 10:48
Tags for this Thread
