Chris NottJMB Retrofits
    Mar 2004
    29
    cruise control fitment
    Hi all,
    Is it possible to hook up cruise control on a non cruise controlled 1998 A6 Tdi SE?
    If so what parts are needed.
    cheers
    Dave
    dreddg's Avatar
    Jan 2005
    Kent, UK
    81
    Re: cruise control fitment
    yes it is possible, as mine was non cruise control, had it done at AMD, did a top job.
    You can buy the stalk from VAG parts, about 35.00 and they also do the wiring as well. You will need someone with vag-com to let the car know you have cruise control.
    Have a look at
    www.vagparts.com
    have fun : [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    Vance's Avatar
    Aug 2005
    Norfolk, UK
    9
    is that al you have to do? just add the stalk and tell the car it's there?
    imported_grantos
    no, in some cars there is a wiring loom that needs to be fitted and also a wire to connect the clutch pedal, we also fit this for the bargain price of 75+VAT
