Chris NottJMB Retrofits
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By adamss24
Thread: C5 A6 2.5tdi DMF probs - advice please
    HerefordQuattro's Avatar
    Hereford
    303
    Question C5 A6 2.5tdi DMF probs - advice please
    Recently had big probs getting into gear especially first/reverse and a lot of vibration through clutch pedal at top of travel.
    Fairly sure this is a terminal DMF but like to confirm before i have to fork out £400 + £180 for clutch while we're at it!
    only query really is that when it's cold it's very bad but last couple of days it's been fairly mild 7-10deg and it's not been too bad (usable) I'm guessing temp will exacerbate the problem??
    If it is DMF then where's the best place to buy? seen LUK on euro Car Parts for 400 notes and if i can wait for their next 25% sale then could get it for 300 or is it best to find a Sachs?
    What about a solid flywheel conversion? not much definative info about on these but would seem a good idea as I fear the increased torque from remap (460Nnm) is what killed the original - but only do 6k a year so DMF should last a while (it does get driven like it's stolen at times!)
    all advice / opinions welcome.
    cheers and merry Christmas
    A6 Avant 2.5tdi Quattro Sport 220bhp 458Nm 6 speed Manual
    Hereford
    303
    just another note, would the DMF failing cause it to idle badly? it's quite frankly a ***** to drive in stop start traffic at the moment but once you're up and runing it's fine...
    Jul 2007
    London
    3,252
    Yes it will ! The DMF works in 2 planes so it must got overheated badly in order to cook the springs inside and the grease to leak out. Did you ever get the clutch slipping ? The only upgraded clutch from SACHS SRE range is rated at 15% increase but knowing how conservative Sachs are with their ratings it's most likely close to 30% increase. I would go and get their organic clutch disc and a stock DMF while at it. Your a6 done about 200k which is good life from the clutch, many modern engines struggle to reach half that ! The remap and perhaps your driving style was the last nail in the coffin for it !
    FOR SALE:
    Hereford
    303
    cheers Chris
    any thoughts on this : Audi A6 Stage 1 Black Diamond Organic Clutch 268.68 at Motorsport World
    or where to get a sachs organic? do i need the cover: Audi A6 Sachs Clutch Cover 294.98 at Motorsport World as well as organic plate: Audi A6 Sachs Friction Plate 246.53 at Motorsport World if so it's going to be £550 just for clutch!!!? (not in my budget)
    what about oem LUK DMF from ECP? any good?
    do i need release bearing as well?
    is it possible to chnage on the drive with only 4 axle stands and a trolley jack or 2?
    ps on the guiness now so above may not make sense!
    Aug 2010
    1,540
    i wouldnt attempt to change a clutch on one of these on the floor. that 'box is fooking heavy! and the top bell housing bolts are an arse to get to.
    id stick with a standard set up and just make sure when youve changed gear that the clutch is up and bitten before you boost it up y0.
    Jul 2007
    London
    3,252
    As advised by Muran, i would not attempt a gearbox removal on your drive as the box is heavy and there's not enough room + i had a car fell off axle stands once. The way i do it (when on my drive !) it's by taking the engine off, much, much safer when the engine hangs from a crane !
    As above, stock clutch is very good as long as you don't ride the clutch and it's fully engaged, it's only when it slips that the flywheel springs get cooked. I tow a lot (at least 2-3 times a week) with my allroad and i don't have any slipping issues, the car is at 160k and when i rebuilt the engine last month, i wanted to replace the clutch but there was no need. I had a bit of play in/out on the DMF but not excesive + there's no judder and it feels fine.
    The clutch you posted in the link is no good for your a6, it's designed for a 2.5 tdi Inline 5 cylinder engine and it's solid, you need a sprung disc... There's 2 types of clutches fitted to the a6 180Bhp: 1 is conventional sprung disc and DMF either Sachs or LUK, the other is a self adjusting clutch and DMF made by LUK. To be honest i hope you have the non adjusting type as it's better and more reliable.
    See this link for the clutch you need: 2.5 TDI (132 kW ; 02/2000 - 01/2005) - Sachs-Performance
    FOR SALE:
    Hereford
    303
    top man
    hang on I've seen the price now!!
    with tax and delivery at current exchange rate = £430 just for the clutch
    Hereford
    303
    I've edited my links now mate as you rightly said it was for 5cyl transporter engine, god knows why as the links i copied were 3 seperate ones all for A6 parts (computers!!)
    Audi A6 Stage 1 Black Diamond Organic Clutch �268.68 at Motorsport World
    Audi A6 Sachs Clutch Cover �294.98 at Motorsport World
    Jul 2007
    London
    3,252
    Stick with the Sachs SRE IF you want a stock feel on the pedal and reliability. Sachs are very conservative with their ratings and the 15% increase is much more than double the factory clutch + you get their experience and a clutch designed for a diesel not a modified petrol clutch ! 450Nm at 2000 rpm's is a lot harder on the clutch than 450Nm at 4000 rpm's !
    FOR SALE:
    Hereford
    303
    ressurecting this thread now i've finaly got my arse in gear.
    ordered parts from Euro car parts in the end (all i can afford) but the clutch kit I ordered was an LUK and they've sent me a Valeo 826640? checked the valeo code and it's the right part no for my car but any ideas on the quality? I'm sure i'm perfectly within my rights to phone them up and ask for the LUK I paid for but need it for this weekend so will the Valeo do?
    cheers
    Jake
    Jul 2007
    London
    3,252
    Take it back and get a LUK or Sachs clutch kit, the Valeo is not man enough for the job !
    FOR SALE:
    Hereford
    303
    wish i'd read that this morning! I thought as much, phoned ECP and the women on the phone said valeo is what had been delivered to their warehouse and is of an equal quality!
    going to have to try and source an LUK or sachs by the weekend arrgh
    Aug 2010
    1,540
    isnt valeo a french company?
    Hereford
    303
    yep wiki tells me they're French, not heard of them till this clutch turned up.
    sourced a LUK one now (on route with fedex as we speak) just got to get ECP to pay for the return postage on the goods they supplied to me not as described
    Hereford
    303
    Ordered LUK clutch from Car and Commercial Parts, Spares, and Accessories - Partservice phoned them up rather than pay through ebay and they gave me free postage in return (no fees fro them).
    ordered at 10am Thursday and it was Fedex'd up from Exeter warehouse and with me by 9.30 Friday, top service.
    Mechanic has fitted today and txt me to say the old DMF was 'badly damaged' so I'll try and get some pics up tomorrow when i pick her up
    Hereford
    303
    wow it's like a new car! I hadn't realised how bad it had got after living with it get steadily worse.
    sooo smooth like it should be
    Jul 2007
    London
    3,252
    Glad you sorted it out ! They feel good when working right them v6's, don't they ?!
    HerefordQuattro likes this.
    FOR SALE:
    Hereford
    303
    YEP!
    Another oil change due soon and got a fuel filter for her as well, keep the old girl going a bit longer!
    Bit like Triggers broom "had this broom for 20 years - it's had 17 new heads and 14 handles but it's the same broom!"
  1. clutch and flywheel advice 2.5tdi
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2011, 22:34
  2. Advice on valuing 2003 A4 2.5TDi
    By DavieMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th January 2011, 16:49
  3. 51 A6 2.5tdi multi, advice needed
    By Johnnybgood in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th October 2009, 15:59
  4. 2.5tdi advice
    By steviequattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd September 2009, 13:30
  5. Advice needed please on handling suspension probs!
    By johnnythepie in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th April 2009, 22:48
