AH FabricationsVolks Autos
    Feb 2008
    26
    Audi A6-C6 drivers door trim removal help please
    Hi,
    I am trying to removal my door trim (drivers and front passenger) to install handle lights.
    This was really easy on my old c5 Audi, very different on the C6.
    I have found instructions to remove the required screws (one under tweeter, two under metal strip, one in the door handle and the other right at the bottom of trim.
    My problem (or fear) is pullIng the bottom of trim outward without breaking it!
    Can somebody who has removed this trim please tell me the position to pull from?
    There is a rubber seal that runs all round the door trim. Not sure if I should be pulling between this on the inside or outside of it. Hope that makes sense. :D
    Aug 2010
    1,540
    you have any pics?
    usually when you pull them off the door the popper break anyway as theyre rubbish.
    Feb 2008
    26
    Hi,
    Thinking about it more, if I do manage to break any clips, I could grap more off Audi cheapy?
    Any idea of part number on clips :S (12)
  1. Selling S3 drivers door lower trim
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2014, 10:50
  2. Drivers Door Mirror Removal
    By CMD in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2013, 01:09
  3. 51 plate A3 Drivers door card removal
    By robgosty in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2010, 20:31
  4. Drivers side door trim on S3
    By Scraggy87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2009, 00:06
  5. drivers door exterior trim fallen off
    By ocalld in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd September 2006, 18:22
