JMB RetrofitsAH Fabrications
    Nov 2011
    Slight Misfire 2.0 TDI A^
    Hi All
    I have just bought A6 2.0 Tdi and am chuffed to bits as the car drives great and looks good just completed a 550 mile round trip. However When on tick over I have noticed a slight misfire / judder which you can feel throuout the whole car, also when I rev it up it is possibly a bit fluffy at about 1600 rpm but then clear straight after that. The car has Loads of power and cruises around town and on the motorway I am half way through using a bottle of RedEX injector cleaner and I am using the higher grade diesel at the pump. Any thoughts would be greatly apprecieted. PS its an 1 owner ex lease car with boat loads of history inc cambelt done at 75k
    Many Thanks Dan
    May 2006
    UK
    167
    could be injectors......quite common. also quite expensive...leave the car on tick over / idle for 10 minutes and see if you get a white smoke. I had to do my car 2 months ago....I hope you sort it.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
  1. A6 2.0 tdi Misfire
    By garya6 in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 1st March 2012, 21:48
  2. 2.0 TFSI Misfire/slight hesitation advice needed
    By B-J-P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2011, 21:06
  3. 1.9 TDI Misfire ... still there!
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th February 2011, 09:52
  4. a3 2.0 tdi slight misfire at idle ??
    By westu_123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th August 2010, 11:28
  5. a4 2.5 tdi misfire
    By Leea4tdi in forum Diesel forum
    Last Post: 27th April 2009, 19:26
