JMB RetrofitsAH Fabrications
Results 1 to 14 of 14
    hazey7's Avatar
    Sep 2009
    170
    3.0 TDI Engine Light on.....
    Hello all, the goddamn yellow engine light is on; has been on for about 2 weeks, but car is running fine, am sure its just a glitch.... is there any way I can reset this without resorting to putting the car on a VAG computer thing?
    Any advice gratefully received
    A6UYC's Avatar
    milf
    Sep 2009
    35
    You know the engine light comes on for a reason !! Why on earth would you want to reset it with out finding out what's wrong.
    It's more than lightly a failed sensor.
    May 2006
    UK
    167
    If you are near me I can help. TW1 Twickenham...I have a plug in reader. Let me know.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    hazey7's Avatar
    Sep 2009
    170
    Unhappy
    Thanks mate, I appreciate your good intentions, unfortunately I am by Chester.
    It went off for about 5 days, has come back this morning
    Jun 2009
    Lincolnshire uk
    Hello I have the same problem yellow engine light on, 3.0 tdi A4, only owned it for a few weeks. I noticed it was on today, been fine other wise, any ideas what yours was????
    kite's Avatar
    Oct 2007
    East Berks
    675
    the 3.0 diesels have a problem with swirl flap motors that are built into the inlet manifolds.
    Expensive fix, it realy is best to have a fault scan to find out what the problem is....l
    A4 (b6) 2.5 TDi QS Saloon.
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    If you are near Chester, I'd recommend Central VW / Audi. See Simon or Peter and they'll sort you out. Best get it scanned to find the fault code etc.
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
    Aug 2010
    1,540
    got a fiver on it being the throttle body.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Quote Originally Posted by murran View Post
    diesel with a throttle body !!!
    hazey7's Avatar
    Sep 2009
    170
    I will take it to central as I had it serviced there. My mate has a 3.0 TDI he says its something in the inlet manifold too.... aOh, and its expensive, like £1K job.... Great.
    Anyone want to buy an 07 3.0 TDI le Mans? lovely car but has a yellow light on.
    Aug 2010
    1,540
    its a throttle body but not a throttle body. it looks exactly the same as a throttle body, but its more of a shut off flap but it has a motor and position sensor etc in it.
    the plastic cogs in them wear out, the're crap. fitted one on a q7 last week 07 plate with 80k on it, the second one we have fitted. first one was two years ago. £300odd for a new one. only takes 15 mins to fit and do the basic setting on it tho.
    kite's Avatar
    Oct 2007
    East Berks
    675
    Didn't know you could get the motor on its own, thought you had to buy the minfold...
    hazey7's Avatar
    Sep 2009
    170
    Well I like a throttle body but I also like the one that's more of a shut-off flap, I wonder which is best?
    Going to Central this afternoon for diagnosis - fingers crossed
    hazey7's Avatar
    Sep 2009
    170
    Well, I think 'Kite' is most likely correct, its the same problem as on my mates Q7 3.0 TDI and is a common problem,
    Fault Code: 'INT MAN B2 LOWER LIMIT NOT REACHED' which is something to do with a motorised flap and the plastic bits associated with it, I wasn't quite sure what he said, my ears had stopped listening, my eyes glazed over, there was a roaring noise and my head started to pound.... around £1,400 for this little job - parts are £500 to £600 PER SIDE.
    I am gutted; you used to be able to get a replacement engine for this money.
    Anyone know a way of working around this problem?
  1. Coil Light Flashing & Engine Management Light
    By vik007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2012, 19:43
  2. Engine light and electronics light on
    By Dannyhall in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2011, 07:57
  3. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  4. engine management light and traction control light always on
    By martin9k in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th April 2010, 13:31
  5. Engine management light and ESP light on
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2005, 14:30
