    Mean Green Machine
    Mar 2011
    Co. Clare, IRELAND
    21
    passenger side door lock not engaging...wreckin my head!!!
    anyone encountered this difficulty. the door closes but just doesnt go all the way.
    have shot some lube into the lock hinge, but seems to be a temporary fix only!!!
    Any ideas???
    thanks
    2002 A6 Avant Sport 130 BHP TDI
    I've had the same problem with my 2003 A6 as well so today I took the door to bits with help from this: AudiWorld Tech Articles
    Been driving me up the wall especially when passengers get in and keep just slamming the door like it’s gonna make a difference!! Anyway I digress. Whilst I did not open up the inner workings of the electric motors on the latch mechanism I did split it into the two pieces. This gives you a reasonable amount of access to the mechanics that keep the latch working and in place.
    First I cleaned all the old grease out as best I could, left it all to dry out a bit (I used a bit of gunk). Then re-applied grease to all the moving parts making sure everything was well covered. Re-assembled the unit and connected to the wiring loom. After a quick tested all was well.
    Once happy all was good I re-mounted the latch mechanism, popped the window frame back in and lined it up (Normally a pain in the arse! But was spot on 1st time). Bolted it all in and closed the door. So far, so good everything seems to be working and after a few more test I was happy. The door seems to be latching properly and the door alignment is better than before I started!
    Sorry I’ve no pics but couldn’t find the camera this morning. Hope this helps
    Rob
    N.B. The two bolts holding the latch in the door were a real pain. I ended up ruining one of the bolts so make sure you use A) the right tool & B) penetrating spray.
    Mean Green Machine
    Mar 2011
    Co. Clare, IRELAND
    21
    Thanks Rob, after much research including readin your link, i opted for a dose of WD 40 into the latch followed by some lithium grease and hey presto...seems to be doing the trick....no more repeated banging of the door to get it closed. Hope i havent jinxed it!!! the only thing i have learned is that an a6 front door has the same weight as a barn door, and new users dont factor that into the equation when they slam it like it was a door on a Fiesta!!! the Education goes on!! " just feel the weight of the door and let its own momentum close itself!!!" thanks again.
  1. Audi A3 drivers side door lock not working
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2011, 01:35
  2. Passenger side door....
    By Sanj in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2010, 16:42
  3. Wanted - Passenger door side skirt
    By Tom Mineral Grey S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2010, 22:19
  4. passenger side door trim
    By twofivenine in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2007, 22:07
  5. Passenger side door
    By a3daveo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2007, 23:55
