Volks AutosBadger5
    Rossy's Avatar
    Feb 2011
    93
    2001 Allroad C5 2.5 tdi Auto Tip Gearbox Oil and Diff change?
    At 156k I think it’s time to do the Gearbox oil/Filter and Diff oils...
    Anyone offer and "easy" to follow guides/walkthroughs ideally with Pictures etc...
    That or recommend a reputable garage in the Bolton/Manchester region?
    It seems at times in MANUAL tiptronic mode more obvious, like riding the clutch if that makes sense?
    I.e. will go around a corner in 3rd engine will sound like its in 2nd then engine note will indicate its engaged 3rd..like its slipping?
    But once locked in a gear is fine and knowing how crucial the oil is to the opperation and its miles just hoping its that and all will be well?
    Hope that makes sense..
    Oh, also, I read that you should not use any "adatives" like the lucas stuff, is that true and why what effect can it have and why?
    Much appreciated...
    Rossy
    Jul 2007
    London
    3,258
    Only use the genuine oil and strainer and make sure the garage know how to fill properly the gearbox...the level is checked at the right temperature !
    FOR SALE:
    Rossy's Avatar
    Feb 2011
    93
    So are you saying its a garage only job and not a DIY?
    Jul 2007
    770
    I think its an Audi only job cos if theres any mistake the box is toast.My A4 is in there now cos someone took the wrong drain plug out!!
    Fraser's Avatar
    Aug 2003
    the north
    586
    Quote Originally Posted by Rossy View Post
    Unit 20 | Audi RS6 servicing, RS6 tuning and Audi RS6 brake upgrades
    Aug 2010
    North east
    69
    you have to have vagcom plugged in to monitor temp, has to be done at certain temp and drains and fill from same point, so you need pump.
  1. 6 speed 4WD gearbox and front diff oil change
    By pj123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Weeks Ago, 10:23
  2. Gearbox and Diff Oil change, How To
    By D8UGF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2011, 09:42
  3. C6 avant auto gearbox oil change
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th May 2011, 22:03
  4. 'Slipping' Auto gearbox 2.5TDi Allroad?
    By toadusmodus in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th March 2011, 13:45
  5. Auto Gearbox oil change at 70K ? / DIY methods
    By RogerTDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd October 2006, 08:54
