Badger5Chris Nott
Results 1 to 7 of 7
    TwistedMind's Avatar
    Long Live The A6
    Jan 2011
    115
    A6 C5 Windows !!!!
    Passenger window not closing properly, going half way up then opening again. Is this the windoe regulator ??
    Can it be re greased or is it time for new parts from ebay ?? 19.99 for kit.
    HELP !
    Audi A6 1.9TDI 2000
    Love the problems !
    Jul 2007
    London
    3,256
    Most likely the clips if the window goes up and down...
    FOR SALE:
    Dec 2010
    Wellington, Somerset
    108
    This suggestion may not help but if you disconnect the battery from the car the windows can go a bit strange and need to be fully opened and shut before the 1 touch open works.
    How about trying the reverse, disconnect the power (maybe just the window motor fuse if you have any doubt about radio key code!) then see what happens?
    Otherwise I would be tempted to strip the trim off the inside of the door and see what is going on with the window mounting/clips etc.
    reggieroo's Avatar
    Worcestershire
    260
    I have exact same problem with my passenger side window. Sometimes it goes up no problem, other times it seems to struggle to go up, gets half way for example then goes back down again automatically.
    Audi S6 Avant 4.2 V8 Quattro 340bhp, 19" OEM RS6 alloys, running on LPG.
    Have you tried spraying the window runners with a bit of silicon spray lubricant. Its amazing what a difference cleaned and lubricated runners can do. My rear window kept popping out of its runners until I gave it a clean and a spray.
    Rob
    May 2006
    UK
    167
    I agree, silicon window runners, if the window meets resistance it will open. make sure you use silicon though as it is water resistant. Should work.
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    Rza
    Mar 2011
    if you need any parts let me know as im striping a a6 c5
