    Aug 2010
    North east
    69
    advice and help needed on lcd clock cluster
    Hi
    my clocks lcd cluster has more lines missing than working lol, found these on ebay
    LCD CLUSTER DISPLAY - AUDI A3 A4 A6 S3 S4 S6 VW - VDO on eBay (end time 20-May-11 21:02:17 BST)
    cant see VDO anywhere on my clocks so plugged vag com in and it read Kombi+Wegfahrs M73 D05, will this screen fit my clocks and has anyone fitted one of these, probs and advice would be welcome.
    cars a 1999 A6 4.2 v8.
    Regards George
    Aug 2010
    North east
    69
    the answer is NO, my clocks are jaeger not vdo, the one i needed which Ive got now has a offset ribbon. will put pics up of both, so if anyone needs a display for a vdo clock set, you know where there is one. :-)
    regards
    reggieroo's Avatar
    Worcestershire
    260
    I need one too as my LCD unit is the same, can read much at all. I wondered how hard it would be to fit one of those on ebay?
    Audi S6 Avant 4.2 V8 Quattro 340bhp, 19" OEM RS6 alloys, running on LPG.
    Aug 2010
    North east
    69
    The answer is its def not a diy job, Its a nightmare to strip clocks down for a start, all pointers and dial motors have to be removed but thats just a pain, the impossible bit is the soldering of the new one, I use a electronic repair company through work and they agreed to solder new one in for me, there verdict was cant be soldered the normall way, so if you have good soldering skills and have a soldering gun that uses a very very fine jet of very hot air, Around £1600 worth of solder gun, it can be done. if you dont have this get someone who has to fit. after all that you need vagcom to reset all your dials. now clocks back in screen looks great till it goes dark then bright then goes all scrambled up. so my advice is send clocks away to be repaired or find new clocks.
    Regards George
    reggieroo's Avatar
    Worcestershire
    260
    Quote Originally Posted by a6george View Post
    Regards George
    I kinda thought that might be the answer
