JMB RetrofitsSky Insurance
    Apr 2011
    7
    Any help on this warning light
    Any takers on what this warning light is for, i have looked in the manual and cant seem to find it at all.
    Any help would be appreciated.
    Uploaded with ImageShack.us
    Apr 2011
    7
    sorry about it being the wrong way, it should be rotated anti clockwise so the bottom of the dials are at the top..
    Dec 2010
    Wellington, Somerset
    103
    Bit of a guess but could it be the self leveling headlamp system? Have you changed a bulb lately?
    Mine did something similar after the headlamp unit was replaced following an issue with a wall in the snow.
    My fault code reader said the fault was that the headlamp unit had been unplugged but after erasing the fault code the warning lamp went away. Did have the alignment tweaked by Audi though.
    Apr 2011
    7
    not sure, its still on now, i have had a new set of clocks fitted when i bought the car, and the bloke hasnt programmed them right, so am taking the car down to a garage on monday to get reprogrammed and hopefully that will sort it all out, as i have no RPM needle movement nor do the center display work just that warning light on thats it. i get no gear indiacation or the big OK in that window.
    will let ya guys know what the diagnostics guys say.
    One thing is that its a strange warning light as it appears no where in the manual, i was maybe thinking it is a warning lamp to say that the clocks have been removed as it looks like that with cables trailing behind.
    By the way the lights work fine and move and i dont think i got auto levelling lights, cos i have a rotatable dial next to the light switch to lower or raise them so defo cant be that.
    Apr 2011
    7
    update, been to audi and they dont even know what the symbol means, so am a bit stuffed so to speak. i went to another place that reprogramme instrument panels and they are saying that the instrument panel is corrupt, so am taking car in on thursday to reprogrammed by Audi, lets hope this rectifies the problem, but would still like to know what the symbol means.
    Apr 2011
    7
    ok update went to Audi in Truro and they had to program my clocks for me, found out what the symbol means and that is Corrupt clocks, i.e they have been removed and dont match up or isnt speaking completly to the ECU.
    Cost me £110 incl vat to have the clocks reprogrammed.
    All i need to do now is find a mileage specialist to put back on the original miles from the MOT cert.
