Badger5Chris Nott
    Feb 2006
    Lancs
    Question 1999 A6 1.8T Coolant Temp Gauge Problem
    Hi Guys, just after a little help here.
    When i turn on my ignition the temp guage picks up a reading, but as i drive it drops down to 60 degrees as though it is not working?
    I have also noticed that the oil temp gauge doesn't move either.
    Today i changed the coolant temp sensor but the problem is still there. I can keep my foot on the accellerator and the gauge will go up to 80+ degrees, but once i release the accellerator it will return to 60 degrees?
    I have bought a thermostat but havn't got round to fitting it yet. Do you think this may fix the problem, or could it be electrical?
    Any help appreciated.
    kite's Avatar
    Oct 2007
    East Berks
    675
    I would suspect the stat.
    A4 (b6) 2.5 TDi QS Saloon.
    May 2006
    UK
    167
    I would say thermostat too..
    3.0 TDI S Line Quattro Avant, Leather, Bose, Colour MMI Sat Nav, Phone, LED rear + Xenons
    Feb 2006
    Lancs
    Thermostat fixed the problems guys thanks.
    Both the coolant and oil gauges now opperate as they should.
