Monster MotorsportBadger5
Results 1 to 9 of 9
    Feb 2011
    Kent, UK
    17
    'Slipping' Auto gearbox 2.5TDi Allroad?
    Wondering whether anyone can help me with the following? Had the car about a week and have noticed what I would consider a slightly strange gearbox trait.
    A few seconds after a change up up from 1st to 2nd, the revs fall back for a second time, almost like it has changed up another gear but is still in fact in 2nd. Could this be the torque converter clutch slipping?
    Also, sometimes when coasting to a stop or very low speeds, the change down from 2nd to 1st happens with a pretty heavy 'thunk'.
    technics100's Avatar
    Feb 2004
    Co Antrim
    775
    doesn't sound too good. Can you take the car back to where you bought it?
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Feb 2011
    Kent, UK
    17
    Nope, private purchase.
    Fraser's Avatar
    Aug 2003
    the north
    586
    at best a gearbox service may sort you, where are you based?
    do you have vagcom or able to scan it? if so what codes are being thrown up
    there are specialist garages you are able to take it to, depends where you are
    Feb 2011
    Kent, UK
    17
    Quote Originally Posted by Fraser View Post
    No fault codes coming up in VCDS, so I guess I will try an oil change and see if that helps.
    Apr 2010
    31
    just to check, remove the multi plug from the trans, and check for water/dampness, this will fool the trans ecu into doing weird things. i had this on my A4, and after an expensive trans rebuild it turns out to be water in the trans harness.
    Feb 2011
    Kent, UK
    17
    Quote Originally Posted by stimpy View Post
    Thanks for the heads up, worth a look. Any ideas where the multi plug is located?
    Dec 2010
    Wellington, Somerset
    109
    Quote Originally Posted by toadusmodus View Post
    Mine did strange things after being washed, the gearbox seems to work fine but the selector display on the dash (PRND etc) all lights up & is blocked out. My fault code reader says its an implasuable signal from the multi-plug. Assume its due to dampness. If you take the under engine tray off I found it fixed to the lower LHS of the gearbox, mine seemed ok but after giving it a good clean & spray with WD40 & covering the seal in insulation tape seems to be happy again.
    Apr 2010
    31
    the cause of my water in the harness was due to a leaking pollen filter. this filled the passenger floor up with water. several inches worth, over time this worked its way along the length of the harness to the multi plug, in turn causing a short and all sorts of issues. i changed the harness and this sorted it out. not before being screwed by a gearbox specialist for a cool 2500 for a rebuild it didn't need.
