Chris NottSky Insurance
    9
    MMI not showing some options
    Hello there.
    My MMI was updated last year by the previous owner but it's not showing the following.
    Battery Level
    Trip Computer settings
    I'm very new to the MMI so can anyone tell me if this is something that can be fixed as I've heard that an MMI update needs to be configured sometimes.
    Also, am I missing anything else on my list? It's got bluetooth but the button on the 'voice' MFS does not work.
    Oct 2008
    42
    For battery level use:
    The easiest way, at home is to use Vag-Com and do the following:
    Connect VAG-COM
    Select Control Module "07", Click on "Adaptation"
    Select Adaptation Channel: 08
    0-Hidden Menu Disabled
    1-Hidden Menu Enabled
    Enter value "1"
    Click "Test", followed by "Save"
    Close & reboot MMI by pressing "Tel" + "MMI Control Knob" + "Upper Right Selection Button" (all together)
    Press "Car+Setup" together until hidden menu appears, takes about 5 seconds
    Then scroll down to Diag Settings and press enter
    Then scroll down to Car Menus Maske (this is how it is spelt on the UK MMI) press enter
    The find Battery Level and press enter
    Scroll down the the bottom and press Accept Changes
    Press the return button 3 tmes to return to the front screen
    Taken from audiworldforums.com - I think the trip computer should be there as well
