Disk changer
Taroni
Kent
My disk changer will not play copyed disk its still the oem one is there a newer version of the disk changer thats just plug and play that i can put in or is there any other way ?
its 98 model
and i mean normal audio cds not mp3s
thks
Just make sure when you rip the cd that the files are saved in the correct format so can be read by the cd player/ changer. Check and have a play around, can't remember if they should be .wma or something similar, see what file extension the originals are? Try and google it, by mine is ok (2002). Try it in the front/ dash too.
In burn options, make sure you haven't set it to burn without gaps between the tracks. (and you've selected audio CD not data - just checking)
Mine works fine, like the others are saying make sure you have not riped the tracks in MP3 format.
There is a web site that supplies a converter that changes your CD changer into a MP3 socket for flash drives
i used nero9 instead of media player and it works fine now ,thks all
865
998
874
