EM TuningJMB Retrofits
    Jan 2011
    3.0 tdi stalling
    Hi
    I need help. My 3.0 TDI stalls when idling and when coming to a stop at intersections. VAGCOM reported fuel pressure problems but I am not sure what the code was. An independent Audi specialist checked pressure regulator, filter and pump, no problems there. He does not know what the fault is.
    I also noticed hunting rpm at about 1100rpm. The stalling only seems to occur after engine is at normal temperature. rpm dips once and then stalls. Is really frustrating.
    Please help if you can.
    May 2011
    Hi There
    I have exactly the same problem. I agree it is really frustrating and have no idea what to do.
    Somebody please help.
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Did he change the fuel filter? and its worth putting some injector cleaner in your tank. Even better if you change your filter, fill it up with injector cleaner as the engine will run quite happily on that until the fuel comes through
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    May 2011
    I did replace the fuel filter, but the problem is still there.
    Something to mention is that the emmision light is also on.
    Can the Cat be the problem?
