Sky InsuranceVolks Autos
Results 1 to 20 of 20
    Mar 2007
    38
    rear washer problem
    My rear washer has stopped working. Originally I thought it was frozen, like the front one. However after the rest have unfrozen the rear still does not spray. Originally even the pump did not even sound to be working, but can be heard working now although no water comes out.
    Does anyone know if the pipe from the front mounted tank runs inside or outside the bodywork and where the pump actually is?
    Can it be got at without having to take the whole car apart or is it a case of paying through the nose for the stealers to find the problem and fix it?
    Any suggestions as to how to fix it would be welcome.
    As an aside the car is just over 5 years old, but still brings a smile to my face when I drive it.
    Marsmail
    Dec 2010
    Wellington, Somerset
    101
    Have you checked the inside of the rear boot liner. My car did something similar and it was actually dribbiling water on the inside of the rear door rather than squirting the windscreen. The motor for the rear wiper incorperates the squirter nozzle and has a copper tube that, in my car, had worn and split. After replacing the unit all fine (about 90 for the part from audi dealer). If the pump is working but no water reaches the rear window there must be water leaking somewhere?
    330_2_S3's Avatar
    Mar 2009
    LONDON
    242
    I have the same problem...this always happens to me during the cold months on my S3 whilst my dads 55 plate polo is fine :/
    I have given it to the dealer while under warranty to fix and its not a major issue....they seem to fix it rather quickly too so I can't imagine it being a big issue.
    I am gona take the panel on the inside of the tailgate off and investigate....I suggest to use a more concentrate mixture of washer fluid for the future to avoid this problem. I am going to do the same.
    MY 07 IMOLA S3 FOR SALE............
    http://www.autotrader.co.uk/classifi...98ba?logcode=p
    richardaudi0
    Oct 2005
    Flitwick, Bedfordshire, UK
    16
    Had the same problem on my 07 Avant - the frozen washer fluid in the pipework had forced the junction apart. It's located behind the tailgate nearside hinge cover. I removed the upper and lower tailgate trim, which in theory is simple but proved a real pig to release the clips and then reinstall it, breaking a couple of clips in the process. In hindsight, I think the hinge cover could be removed without going to all this trouble.
    2007 Audi A6 Avant 2.0 TDI SE Multitronic. Oyster grey/grey leather.
    TheBigUn's Avatar
    Sep 2010
    7
    Same here with my 2002 Avant. The nozzle had come off during the recent winter weather. The tailgate trim was dripping in leaked screenwash.
    I removed the two screws, one in the tailgate handle recess and the black plastic one in the folding warning triangle holder, then unclipped the lower trim and it came away with the upper trim. Be careful not to let it fall as there are a couple of electrical connections.
    The washer pipe just needed pushing back onto the wiper connector. The clips were hard to align when re-fitting the trim but I sorted it eventually.
    A 10 minute job.
    A6 Avant ~ 2.5 TDI ~ SE CVT ~ 2002
    Dec 2010
    101
    p.s. to my last thread. I have just discovered (off my copy of ELSA) that if the tube inside the wiper motor had corroded/broken as mine had there is a repair kit avaliable from audi rather than having to replace the entire motor unit as I did.
    Mar 2007
    38
    My problem is that there does not appear to be any fluid reaching the rear. There is no evidence of any wet patch or drips at the rear of the vehicle, hence the original query as to where the pump actually was and the routing of the pipework to it
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,691
    I had to chase my pipe from the right hand side of the boot to the front passenger foot well.
    Thats where i found the disconnected pipe.
    This was on a A4 B5, not sure where the pipe runs on a allroad.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Well today i replaced my rear washer motor as the ****e design pured water intot he gears. It cost 100.00 for the motor, but i had to butcher the wiper arm to get it out. Only took 30 mins to replace. but be warned that the hose near the LHS boot hingle can break and pour water onto the MMI system.
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Jan 2011
    Hi there, check your passenger footwell carpet. In my A6 (2003 Quattro Sport Avant) the pipe taking water to the rear wash had separated in the front passenger footwell. See my reply today to a much older post about this. Cheers, Allen
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Quote Originally Posted by Flat 6 View Post
    Can you describe a little bit more exactly where the washer pipes run and where the offending joint is? Did you need to take the seat out to do this ?
    DRS
    May 2009
    Hi, I don't visit often and realise this thread is a month or so old now but...
    I had a 07 plate A6 Avant and the rear washer stopped working so I stopped using it. I then had it serviced by Audi, they replaced the rear washer. Driving home the MMI stopped working...long story short the MMI needed to be replaced at a total cost of 2600. Luckily I got the bill down to 300 though I feel kind of ripped off really, it was probably their fault...it was working before it went in for the service.
    Moral of the story, check your MMI system in the rear of the car anytime your rear washer stops working otherwise you'll have a really big bill.
    Thankfully I now own a nice 10 plate A6 Avant, it doesn't have the electrical assembly in the rear so that's one less thing to worry about.
    All the best
    Mar 2007
    38
    To update.
    The washer pump is located on the washer bottle and can be reached by removing the wheelarch inner liner.
    In my case, the pipe had come off the punp outlet there and eventually I saw water running out from the back of the wheel arch. That is what threw me, I was looking for leaks further back while thinking that the pump was down the back and water was not getting to it from the front!
    Ah well, it has taken a long time for the penny to drop, but at least it didn't cost anything which it would have done if I had succumbed to taking it to the dealer!
    Nov 2007
    485
    STOP what your doing if its a C6 chassis, dont use the rear washer until you've checked under your passenger seat and in the left corner of your boot lid. these are two areas where the hose leaks/splits. Both locations will destroy your MMI (under the passenger seat is the BT Unit and the left hand side of your boot is where the Radio and nav units are.
    I recently had the same problem with mine, have a look at the underside of my passenger seat. Luckily my car has been upgraded to the MMI 3G so there is no BT Module.
    You will see that the hose has become separated fromt eh connector.
    Q7 S Line 2010
    MMI 3G
    Superchip Remap
    Mar 2007
    38
    Cockney boy, thanks for the warning, but if you had read to the end you would have seen that I had solved the problem and was fortunate that the pipe connector that parted was in the wheel arch, not inside the car.
    I shall certainly bear the warning in mind if I am unfortunate enough to have it happen again.
    Perhaps it might save someone else from an expensive "accident"
    marsmail
    Gavin0478's Avatar
    May 2010
    cleveland
    443
    mine went on the boot hinge but i managed to get audi to replace it for free.
    V8 baby... oh yeah
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Hi,
    finally had a chance to look at this on my C5 Avant. The pipe had come apart in the passenger foot-well. To access this you just need to take 2 screws out of the side "kick plate" and pull to one side. You can then pull the carpet back. The washer hose is behind the wiring loom. As said above, it is right next to a whole load of connector blocks, not the best place to have a join in a water pipe!. There was a cable tie around the joint, looked quite neat so not sure if someone had previously tried to fix it or whether Audi knew this was a weak point. Anyway the good news is that it turned out to be a 5 minute job and the rear washer now works!.
    Dec 2011
    Aberdeenshire, Scotland
    Hi
    Fearing the worst (removing carpets, seats, trims, etc) just sorted a rear washer fluid leak on my 2001 Allroad with surprising ease. There is a flowline union tucked away in the wiring loom directly above where the toolbox is located behind the removable panel nearside rear left. This had separated - probably when we suddenly went down to -8C a couple of nights ago - the toolbox was full of washer fluid! Reconnecting required removing the 2 clips holding the loom in place but thankfully nothing else. Thanks to previous poster for the photo - helped me to figure out what I was looking for.
    Lesson learnt - get the low temp protection into the washer system before it's needed.
    Dec 2011
    I seem to have no fluid coming out and the rear wiper isn't working either. I have a 2003 a6 avant. I ave tried o remove the panel over the rear washer motor etc but can't get it off. I did however find that the pipe had come apart at a connection in the left compartment in the boot.
    Jun 2007
    40
    Feel the carpet near the front passenger footwell if it is damp then you have a broken pipe under the front footwell trim panel. Remove the lower trim panel and within the wiring loom the rear washer pipe which has a join in it. Chip the two back together and then tape it up as the clip will come off again.
