AH FabricationsJMB Retrofits
    Dec 2009
    6
    a6 2.5 tdi quattro heating problem!
    Hi all, i'm wondering if anyone else has had this problem! It seems to take ages to heat up the inside of my car,it's a 2000 model 180bhp. Needs a bloody long run before i can take the hat n gloves off be grateful for any help
    Gavin0478's Avatar
    May 2010
    cleveland
    451
    thermostat
    Dec 2009
    6
    cheers gavin, didn't think of that, i'll defo look into it! was thinking of some outragously complex type of problem being an audi!
    Jul 2007
    London
    3,209
    Quote Originally Posted by skwiffy333 View Post
    You're not that far off ! Thermostat is a belt off job wich will set-you back a good few hundred pounds !!!
    FOR SALE:
    Watty's Avatar
    ..... (_!_) Sarah's A3s #1 Fan
    Railway Line Champion
    Sep 2007
    Perth, Western Australia
    406
    The 2.5tdi V6 is know for cool runnings, mine barely moves from 60 in this weather, but a blast down the motorway gets it up to around 75/ 80 max. I've been told that they are very heat efficient and the exhaust takes away most of it. Wouldn't bother doing the thermostat unless at a belt change.
    Audi A6 Avant (2002) 2.5 V6 Quattro. Sunroof, Bluetooth mp3 Xcarlink, 6cd, xenons, tints, ST3, 18" RS6s
    I have VCDS and I'm not afraid to use it, well, a little bit?
