AH FabricationsBadger5
Results 1 to 11 of 11
    In pursuit of audiness:)
    Feb 2009
    282
    19" wheels on a6
    Hello
    Recently i bought a6 2.7 tdi 06 sline. id like to get 19" wheels on it they called a6 speedline (a lot of spokes) but i need advice with size 8j,8.5j or 9j and what offset and finally
    what tyres size to make archers filled nicely and no rubbing?(ive seen a lot of a6 with these wheels and they match archer line so nice) Please advice me
    Audi A6 2.7 TDI S-Line
    Mods - |Remap | 18" rs6 wheels |
    To be done - 19" wheels | Tints | Sat nav retrofit | RS6 steering wheel
    Feb 2009
    282
    nobody??
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    I have 19" S5 Alloys on mine, and the are 33 offsets, so they do stick out a little but dont rub. If you get a 35 offset of greater these will fit inside the wheel arch nicely
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Feb 2009
    282
    thanks for reply. what tyre size do you have? im about to order rs4 19" et35 and possibly tyres 245/40/19 will they fit?
    Gavin0478's Avatar
    May 2010
    cleveland
    453
    255/35/19 is the norm
    Feb 2009
    282
    will i have any rubbing problem with 255/35/19 and et35 wheels?
    Garpemo's Avatar
    Mar 2014
    32
    If you have S-line will 255/35/19 rub on 8J ET35?
    Using Tapatalk
    Garpemo's Avatar
    Mar 2014
    32
    Forgot to tell on a 2004 A6 3.0 that is.
    Using Tapatalk
    Mar 2011
    61
    Running 19" speedlines on your A6 is doable, although if you've not sorted the ride height it will look like a tractor. Obviously depending on how low you go effects what ET and tyre choice you make.
    Are you running standard ride height?
    Garpemo's Avatar
    Mar 2014
    32
    Yes. It's factory lowered S-line. I've noticed that it's lower and stiffer.
    Using Tapatalk
    Garpemo's Avatar
    Mar 2014
    32
    Using Tapatalk
