Chris NottVolks Autos
Results 1 to 7 of 7
    69COU's Avatar
    Jul 2006
    Kent
    62
    How to set Long Life Service mode with VAG COM vs409
    Hi
    When I got my A6 it had been serviced by main dealer and read 20,000 miles to next service & around 600 days from memory. Since then when ever it gets serviced it sets to 9500 miles and 365 days.
    How do i reset to longlife service mode. Since I am paying for expensive oil I would like to put back on long life mode.
    2003 - A4 1.9TDI......&......2002 - A6 2.5TDI
    Both Black with Black Leather.
    kite's Avatar
    Oct 2007
    East Berks
    660
    with vacom, or the dealer should set it...
    69COU's Avatar
    Jul 2006
    Kent
    62
    I have VAG Com hoever think need to do more than than the reset of Channel 2 within adaptation instruments module which resets service, but does not switch back to long life service.
    kite's Avatar
    Oct 2007
    East Berks
    660
    Use the SRI reset function on vagcom, you can choose which service interval you want.
    Ross-Tech: VCDS Tour
    Aug 2010
    1,540
    if you plan to keep the car id get it off long life servicing and put some proper oil in it. its a total gimic. the expencive oil you pay for is soooo full of detergents they forgot about the lubrication............... save your cams now before its too late!!
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    Do you have any evidence of this happening? Im sure it would be an interestig read along with a conversation with my Audi Dealer.
    Quote Originally Posted by murran View Post
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
    Aug 2010
    1,540
    not on your model of audi/engine as yet.
    but cams, rockers, tappets on 1.9 tdis, old 2.5 tdi a4s, audi tt cam bearings, old 2.8 30v a6 a4 cam bearings. oil pick up strainers blocked with carbon deposits on various audis/vw/seats.
    its hard to pin it down as long life oil causing these faults with cars ive worked on/fixed/seen 1st hand. but its all in common (lubrication). ive got a tenner says, if the cars id seen had normal oil in and changed every 8-10k they wouldnt have had the problems.
    whats a simple normal lube service cost? 80 100?
    20oddk on the same oil?.... id worry, put it that way.
