    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    A6 1.9tdi 130 help please
    Hi
    i have an 2002 A6 1.9tdi 130
    im having a problem i cant seem to get to the bottom of
    whats happening is when i start it from cold it dies and stops again this happens several times then eventually it starts but you have to hold it at 1400rpm ( while at this rev its hunting ) do this for about 4 minutes then it idles fine .
    I changed the fuel filter ,
    then ran a diagnostic where errors for the air mass / map sensor came up i run actual values and these were both reading out of spec so i changed them ( also was loosing power and black smoking so these made sence as errors ),
    I left the car till the following morning and no difference at all
    just wondering if any one has had or no what should i do next as im running out of hair to pull out
    thanks in advance
    Paul
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Could the EGR valve be giving problems
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    i had thought about that also the shut off valve ,
    i will have too look in the day light on sunday as im away at the moment
    thanks for the input thou
    its driving me dull now .
