Monster MotorsportChris Nott
    reggieroo's Avatar
    Worcestershire
    260
    Hazard warning light switch faulty, crackling sound?
    I keep hearing a crackling sound coming from the dash, just above the stereo. It sounded like it was the hazard warning light switch, when crackling I turned the hazard's on & it stopped.
    Also when looking through the receipts, I noticed that on the 10/04 it had a hazard switch/indicator relay replaced under warranty.
    It's on my 2002 allroad but guessing the switch is the same on all A6's, is this a known fault?
    Aug 2009
    200
    Not sure if it is a "known fault" but is certainly common and a fairly easy fault to fix if the Hazard/flasher unit fails. The links below tell you how to get the Hazard Switch/Relay (it is single module) out and also how to affect a fix to the relay that might work.
    No-warranty-guinnea-pig update #4 - Blinker Relay Failure - AudiWorld Forums
    AudiWorld Tech Articles
    If I recall correctly the cost (a couple of years ago) of a new switch from Audi is about 30
    Hope this helps
    2012 A6 Avant 2.0TDi SE
    1970 Lotus Elan +2S
    reggieroo's Avatar
    Worcestershire
    260
    Quote Originally Posted by elan2s View Post
    Hope this helps
    I went & bought a new one from Audi yesterday at 41
    I'll have a go at fitting it today if I get round to it, thanks for the links.
