Volks AutosMonster Motorsport
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    2005 A62.4SE (C6 model) - cambelt or chains?
    I currently have a 2003 A4 2.4SE (B6 model), which has belt-driven camshafts.
    I'm contemplating buying a 2005 A6 2.4SE (C6 model), and have been told that this version of the engine has chain-driven camshafts.
    Can anyone confirm whther this is true or not?
    Thanks in advance.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    Jul 2007
    London
    3,070
    Most likely it will have cambelt but you should get a engine code just to double check. Will it be the c5 or the c6 model ? The quad cam engines have chain tensioners inside the heads to allow for the variable valve timing but the engine is still cambelt driven... The 3.0L petrol engines are also quad cams but they have 4 sprockets on wich the belt go as well so no more VVT but these engine are direct injection and as such they can inject fuel in multiple squirts inside the cylinder just like the TDI engines do...
    FOR SALE:
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,312
    Update
    I've just spoken to two different Audi dealers, given them the registration number of the specific car and they have both independently confirmed that the camshafts are chain-driven, not belt-drive, so no replacement necessary.
    Cockney Boy's Avatar
    Nov 2007
    Aylesbury, Buckinghamshire, UK
    485
    All V6 engines have a chain
    Q7 S Line 2010
    MMI 3G
    Adaptive Cruise Control
    Superchip Remap
    Blackvue front and rear accident camera
