Well guys, got the DRL's fitted today
These are the ones I fitted
link
Really reasonable at the price I thought and they seem exactly the same as the ones on the Autobulbs website as far as I could see.
Anyhow, I started by removing the fog light housings and offering them up into position. They even followed the curvature of the housing PERFECTLY
I marked the hole positions and drilled the holes to suit.
Note; on the drivers side I had to cut away a hole for the light to fit into. I didn't have this hassle on the passenger side as thats where the intercooler is, so only a pain on the drivers side
It all went well and I got them all bolted up into position and they looked pretty cool I thought...took around an hour and a half I'd say.
Then off to my friendly sparky....He took around 2 hours to complete the wiring and eired them into an ignition feed which means they're on always.
Anyway, I think they look pretty stock from a distance and good even pretty close up....Its only on closer inspection you can see they are aftermarket I'd say, but obviously I'm biased
Cost of lights £45 approx, cost of sparky £30....total cost £75
Please judge for yourself in the following pic fest.....I tried to take from as many different angles, close up and at a distance to give you an idea of how they look. Hope you like....
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 134KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 138KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 156KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 126KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 130KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 129KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 111KB.
This image has been resized. Click this bar to view the full image. The original image is sized 800x600 and weights 149KB.
Jim
