The adapter you need for the rear amped audi system is the PC9-401
Standard System
The standard concert headunit runs only the front speakers, the rear speakers are amped up and so is the sub. they run at the following powers:
Front 2 x 15W straight of the head unit
Rear 2 x 25W off the amp in the rear
Sub 1 x 80W off the amp in the rear
by upgrading the head unit (probably 4 x 50W) you have had the following effect:
Front 2 x 50W straight off the head unit
Rear 2 x 50W which then runs to the Audi amp and reduced to 2 x 25W
The factory amp is lowering the signal to the speakers which is where the well known interference comes from.
What you need to do
1/ remove the plastic inner sills that run down the length of the car
2/ remove the lower part of the back bench so you can pull the carpet up
3/ pull the carpet back to reveal the wiring looms near both rear doors
4/ Find the loom thats got two wires taped up (its held down with duct tape)
5/ unplug the Audi amp in the boot and turn your stereo off.
6/ Cut these two wires to each door.
7/ run new speaker wires from the rear outputs on the headunit along the sills
8/ connect the new wires into the wires you have just cut coming out of the doors
9/ tape up the old wires coming from the Audi amp
10/ plug in the audi amp that now just runs the sub
11/ replace all the trim/carept and seats
12/ enjoy your stereo that now runs at 4 x 50W with an 80W sub.
Standard System
What you need to do
