EM TuningBadger5
    Feb 2011
    12
    Post Thanks / Like
    Would an under tray improve MPG on motorway??
    I read that fitting an under tray can improve mpg, as I've just purchased a 2.5 TDi and will be doing manly motorway miles I'm considering fitting on.
    Even a slight improvement of MPG would save me £££££ with the amount of miles I do a year
    JohnG60's Avatar
    Dec 2010
    West Sussex
    16
    Post Thanks / Like
    It has one fitted as standard, sounds like a garage has failed to put yours back on at some stage - it may make a slight difference in MPG at higher speeds but it mainly reduces the engine noise considerably and helps prevent dirt and grit being sprayed all over your lower pulleys and electrical connections.
    Audi designed the car with an under tray for a reason
    Oct 2009
    Preston
    66
    Post Thanks / Like
    yes it does make a difference - just added the engine and gearbox ones back onto mine.
  1. Will average MPG improve from stage 1 remap - Yes or No?
    By g10chy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2010, 13:09
  2. un modded a3 1.8T r reg any ideas to improve MPG
    By Boggle in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2010, 14:54
  3. How to improve brakes?
    By drew67 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th August 2007, 18:04
  4. help me improve my handling!
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2006, 13:46
  5. Improve 1.8 SE A4 Power?
    By JaceyBoy in forum Tuning
    Last Post: 29th June 2004, 23:19
