JuicyDPM
Results 1 to 7 of 7
    Dec 2011
    12
    Post Thanks / Like
    Tempremental bulb warning light
    every so often during a car journey i get a bulb warning light on my rear left tail lights. All bulbs and lights work fine although after driving for a while the rear indicator stops working closely followed by rear side lights.........if i leave it and restart the ignition it disappears......any ideas?
    North East
    163
    Post Thanks / Like
    Quote Originally Posted by adrenalin84 View Post
    I have had a similar issue for three years now with a number plate light on my Avant. If I turn the lights off and then on the warning light corrects itself, spooky ! Another thing is that this only happens in winter, never in the summer , go figure ?
    Aug 2009
    103
    Post Thanks / Like
    Probably the same gremlin that causes my car to only unlock the drivers door and tailgate on the first push of the remote when it is frosty and in the past couple of days change some of the settings for the SatNav!
    2010 A6 Avant 2.0 TDie SE
    1970 Lotus Elan +2S
    Dec 2011
    12
    Post Thanks / Like
    Today on a motorway journey EVERY rear light came up with a bulb warning! Restarted engine and all cleared until later on
    Dec 2011
    12
    Post Thanks / Like
    Fingers crossed I seem to have fixed it!!
    May 2012
    A, A
    Post Thanks / Like
    So, did you really fix it? How did you do it? I'm going insane with that same issue!!!
    Dec 2011
    12
    Post Thanks / Like
    Quote Originally Posted by victormarx View Post
    I fixed it for about a month :-s I took out the light unit and filed/sanded down all electrical connections inside and outside the unit. Ended up eventually buying some aftermarket led lights from germany which I had to rewire. Now all the lights work fine but I have 2 bulb warning lights on the dash as the new lights only require 1 sidelight, and the old ones have 3. But atleast the lights work! :-D
  1. Bulb Out warning light still on
    By Dibbler in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th January 2012, 17:45
  2. Brake Light Bulb Warning - After Bulb has been replaced !!!
    By silversurfer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2012, 11:47
  3. A3 bulb warning light..
    By stacey bear in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th October 2010, 12:43
  4. Bulb warning light?
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th October 2010, 12:21
  5. Bulb warning light
    By mja4cab in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2010, 17:14
