Adrian S FluxKowalski
    Aug 2011
    Post Thanks / Like
    2006 A6 3.2 quattro with 18" wheels - Snow chains
    Heading off to the French bit of some Alps next month. It's compulsory to carry snow chains. Does anyone have experience of doing this? Can I use them with a quattro, never mind one with 18" wheels?
    Aug 2009
    103
    Post Thanks / Like
    A few years ago I had a C5 A6 (FWD) with 17" wheels. I hired snow chains for a ski trip from Roofbox.co.uk. The only chains they were prepared to offer for an Audi were the Spikes-Spider ones because of clearance issues behind the wheel. The advantage of these were that, because you fit a plate to the wheel in advance, they are quick to fit and the plate helps to protect the alloy wheel both from kerbs and pot holes and also from the chain rubbing against the rim. I have no direct experience of using chains on a quattro but I am led to believe that firstly you are likely to have even less need to fit them in marginal conditions but if the sign says they must be fitted then so be it and that you only need them on the front wheels as you would if the car were FWD.
    Have a good trip
    2010 A6 Avant 2.0 TDie SE
    1970 Lotus Elan +2S
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    what about the composite things costco are selling?
    they look like touch but narrow rope and seem fairly low profile by comparison.
    cant see you ever needing them unless your tyre choice and driving style dictates it.
  1. Snow Chains for S3
    By beanoir in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st December 2010, 10:33
  2. Snow chains?
    By IainP in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th January 2010, 12:50
  3. Snow Chains for 18" 3.2 Quattro
    By Skittler in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th August 2008, 19:43
  4. Spikes Spider Snow Chains?
    By SimonP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2007, 09:03
  5. Snow Chains on 18" Wheels ?
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2004, 22:00
Tags for this Thread
