DPMDTUK
    Dec 2011
    Post Thanks / Like
    a few problems i need help with.....2004 c5 avant
    Right, i dont really klnow where to start as i have a few big things bugging me with the car and a few smaller issues. id like peoples views on:
    a) PRNDS flash - i know its a ECU replacement/fix but what is everyones opinion on this? Repair the existing one or replace with a brand new one (my local garage told me there is a large difference in cost) is there any reliability issues with a fixed one or not?
    b) Occassional water drip from the lighting unit in the front? Usually after a bit of rain, and i dont have a sunroof so its not the gutters there? I pulled the unti out an it all looked ok no water damage? Could it be something to do with the washer pipes (i had a similar issue with my old escort)
    c) Airbag light comes on if i have someone sitting in the middle seat in the back, this is intermittent, is it a sensor thing?
    The water drip and the gearbox things are my biggest concerns. Ive got no dosh after just spending £700 getting the alternator pulley replaced after seizing up (long story).
    jcb
    Sep 2005
    uk
    3,784
    Post Thanks / Like
    1) I would source a 2nd hand one before replacing
    2) do you have a leak at the top windscreen seal
    3) AFAIK there are no airbag sensors or connectors in the rear seats, if there are then you may find they have a high resistance reading and just need cleaning (common problem with B5 drivers seat connector)
  1. A3 2.0 TDI 2004 Problems
    By DiKapo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th September 2010, 09:18
  2. 2004 A3 TDI DSG FUELING PROBLEMS!!
    By maui_matt in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2010, 17:50
  3. 2004 A4 1.9TDI Multironic problems
    By mdurna in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th August 2009, 17:25
  4. 2004 avant full interior into 1997 avant
    By Karlos the Avant in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2009, 08:49
  5. 2004 A4 Avant - What to look for???
    By mattey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2007, 09:27
