W8 PerformanceBadger5
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    117
    Post Thanks / Like
    a6 kangarooing unless at full throttle!
    Hi
    my mate has got a 2008 A6 2.0TDi which has been running poorly for a few weeks. If he tried to drive steadily/normally it would judder & kangaroo mainly in 1st & 2nd but if he puts his foot down it runs better. The engine management light also came on. So i disconnected the maf & it ran perfect.
    I did a diag check & 2 codes came up both relating to the maf. So today i've fitted a new Bosch maf then erased the error codes.
    The problem is the car is still showing the same symptoms but there's no error codes & i've now disconnected the new maf & it's running fine with it disconnected!
    anybody got any ideas?
    Craig
    mobile mechanic, diagnostics, fault code reading/clearing. key/remote programming & also remapping using the Alientech Kess V2
    craigynett's Avatar
    Apr 2006
    117
    Post Thanks / Like
    nobody???????
    Dec 2011
    12
    Post Thanks / Like
  1. Help Needed - Cant Full Throttle !!
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2012, 19:00
  2. 8P S3 Full throttle problem??!!
    By gnic13 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2011, 21:01
  3. S3 lost all power whilst at full throttle
    By jemis in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2010, 08:16
  4. Faster on part throttle than full throttle?
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2010, 21:49
  5. vibration when full throttle
    By marv in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2010, 18:04
